Need a definite answer! - Honda Accord Forum : V6 Performance Accord Forums
Old May 20th, 2003, 06:48 PM   #1
What size tires should I get with 17 X 7.5 rims to definitley not rub!? Dropped approximately 1 inch drop. thanks let me know
v6accord00 is offline   Reply With Quote Quick reply to this message
Old May 21st, 2003, 01:19 AM   #2
225-45-17 more common size
215-50-17 stock Acura CL/TL size
SiR001 is offline   Reply With Quote Quick reply to this message
Old May 21st, 2003, 02:29 AM   #3
You will need to know your offset too..its an important factor deciding whether your going to rub or not...
the higher the better bascially...like 45mm or 48 or even 51mm!
hope this helps..but with those tire sizes that Sir001 said..its good sizes...but offset of the wheel is important too!
good luck..
hondaboi is offline   Reply With Quote Quick reply to this message
Old May 22nd, 2003, 01:25 PM   #4
Must go faster dammit
UrbanVVraith's Avatar
i feel dumb, what the hell does the offset measure?
UrbanVVraith is offline   Reply With Quote Quick reply to this message
Old May 23rd, 2003, 01:12 AM   #5
Hello,
the offset of a wheel measures how much the wheels stick out the fender or not..
the higher the offset (ie: 42mm, 45mm and so on...) the more it will tuck (sp?) in...
the lower the offset (ie: 38mm,35mm and so on...) the more it will stick out off a fender..
basically we (by WE i mean accords) need at the minimum 42mm, some members here have 38mm or 40mm and does not rub...it depends too how much the car is dropped..most likely if its sport springs..its ok...if race, then you will rub!
hope this helps..
Old May 25th, 2003, 10:20 AM   #6
u only got a 1 inch drop thats almost stock. dont worry about rubbing.
Infamous425 is offline   Reply With Quote Quick reply to this message
Old May 25th, 2003, 01:11 PM   #7
HONDA_99's Avatar
here is a picture on what is offset and how to measure it.
here is a link to where you can read what is offset and how to measure it.
http://www.tirerack.com/wheels/tech/offset.htm
