how do you feed a wire through the firewall - Honda Accord Forum : V6 Performance Accord Forums
Old March 22nd, 2004, 01:57 PM   #1
I jabbed a coat hander through the grommet but it never came through. What's teh best way to fied wiring? I plan on installing 4 gauge amp wires. Will I need to drill into the firewall to fit that through?
2000 Accord V6 EX
Current mods:
ICE: Eclipse 3434 HU, PPI PCX-480 Amp, Apline Type-R Component Front Speakers, MB Quart DTC-169 Rear Speakers, Infinity Basslink Sub
Exterior: 18 Axis TC Evo, Catz 4100K HID, Tenzo 200x Fog Lights, Tint, DIY Black Housing, 01-02 Front and Rear Bumper, Hi Performance Stickers
Interior: DIY Gunmetal dash, Reverse Indiglo Gauges
Suspension: Tein SS Coilovers, CL-S front strut bar, CL-S rear sway bar
Engine: AEM SR, Intake Heat Shield, Magnaflow Catback Exhaust, TL Battery Cover
Near Future mods:
Headers
Pullies
Looking for a job?
http://www.v6performance.net/forums/showthread.php?s=&threadid=17052
Old March 22nd, 2004, 05:14 PM   #2
Lumpy's Avatar
Use a razor knife to push and cut the grommet. Once you get it started, use a flat tip screwdriver and push it through a couple of times. Use a little WD-40 or something to lube your line and then just push it through. If you cant get, go back to the razor and screwdriver and work it some more. Make sure you put a fuse close to the battery!!!
Lumpy is offline   Reply With Quote Quick reply to this message
Old March 22nd, 2004, 06:14 PM   #3
yah just punch through the fire wall...use some Windex(soapy water) to have asome slippage
NocturnalCoupe is offline   Reply With Quote Quick reply to this message
Old March 22nd, 2004, 06:21 PM   #4
Old Member
Du3ce's Avatar
ky jelly!!!
Old March 22nd, 2004, 07:08 PM   #5
bryan <3's bomex
mastadulog's Avatar
no man, astroglide
Old March 29th, 2004, 06:33 PM   #6
I used one of the holes on the driver side grommets and it leads you straight inside the car... i installed 2 gauge wires into my car
Accord ASR is offline   Reply With Quote Quick reply to this message
Old March 29th, 2004, 07:16 PM   #7
metallikatz3's Avatar
Send a message via AIM to metallikatz3
i had to cut the insulation on the inside of the firewall right behind one of the gromets to get all my wires thru
metallikatz3 is offline   Reply With Quote Quick reply to this message
