Re-upholster your rear tray for a clean custom look! - Honda Accord Forum : V6 Performance Accord Forums
Old April 5th, 2004, 05:44 AM   #1
Lightbulb Re-upholster your rear tray for a clean custom look!
Here is a "mod" you won't see every day:
I removed the rear tray of my V6 Coupe and then re-upholstered it with a leatherette that matched my car's original leather seats and trim. The end result looks really nice and, since my 3rd brake light is on my spoiler, I also got rid of the "dead" brake light on the deck and I can see out the back window a lot better. Another benefit that I have noticed is that this mod reduces rattling (from B-A-S-S Bass) because it makes things back there fit together a little more snugly.
This is one of those small, inexpensive modifications that I think makes a big difference toward making your car look unique and truly customized. All you need to buy is a few yards of water-resistant vinyl leatherette (Jo-Ann Fabrics), and some 3M Super 77 Spray Adhesive (any decent hardware store). This stuff will only cost you around 20 bucks. You can use real leather instead of the leatherette, but it is expensive and hard to find. To get the best color-match possible take a headrest from your car into the store with you.
Note of Caution
I've had to remove the Accord Coupe's infamous back deck numerous times to install speakers, tint, fire department strobe lights, etc. I can tell you from experience that it is easy to get loose, but a ***** to get out without bending and cracking the fiberboard, so please take your time and be careful!
Once you have the materials, take out the rear tray (I got rid of the never-used 3rd seatbelt in the process).
Once the tray is out, remove the plastic speaker covers, cut a piece of vinyl that will cover the entire surface area of the tray, spray the tray down w/ several coats of fixative (do this outside, you have to do it quick and it can get messy), and then firmly press the vinyl onto the tray; use your hand to smooth out any wrinkles. Do not wrap the vinyl around the lip of the tray to the underside, but make sure that it is glued right up to the edge (wherever there is that carpet-like stuff, you want vinyl glued down--NOWHERE ELSE).
Once you've let the glue dry, trim the vinyl down until it is even with the edges of the tray. Don't worry about the vinyl not sticking around the little holes on the front two corners of the tray where all the bends are, this section will be hidden from sight anyway. Use a razor to cut out the holes for your 6x9" speakers and use an awl or a BIG sewing needle to start the holes where the screws go to reattach the speaker covers (cut and punch holes from the TOP). If you have removed your 6x9" speakers for some reason you can leave the entire rear deck flat, which I'll bet looks pretty cool too.
Finally, make sure you REPLACE the little plastic clips that fit on the underside of the tray before re-installing it so you get a nice tight fit. I ordered my these parts online from Majestic Honda. Now you are ready to re-install the rear tray!
Sorry for the long post guys, let me know what you think of this!!!
Mike
MArany is offline   Reply With Quote Quick reply to this message
Old April 5th, 2004, 06:53 AM   #2
looks good
Old April 5th, 2004, 09:43 AM   #3
New Member
aznfunkyflip's Avatar
DAMN! That's very nice. You did a good job.
Old April 5th, 2004, 10:01 AM   #4
Very good job!!
I might just do this mod since, I've been wanting to get rid of my unused third brake light...
Mike
NauticaV6 is offline   Reply With Quote Quick reply to this message
Old April 5th, 2004, 09:25 PM   #5
do you think there would be any effects from the sun beaming down on the rear deck?
Bucktown is offline   Reply With Quote Quick reply to this message
Old April 5th, 2004, 10:37 PM   #6
I asked about that when I bought the vinyl from Jo-Ann Fabric and they told me that the high-quality stuff doesn't fade any faster than leather (everything fades a little with constant uv exposure, including the original carpet covering). I did this modification late last summer and there has been no noticable fading so far.
Old April 6th, 2004, 10:10 AM   #7
JayDub's Avatar
That's pretty cool, looks good.
Stop by and sign guest book:
JayDub is offline   Reply With Quote Quick reply to this message
Old April 6th, 2004, 10:55 AM   #8
Your V12, My V-twin.
JonHsiung's Avatar
looks good. looks damn good... i think i will have to steal your idea since my third brakelight are LEDs at the top of my rear windshield now.
great idea. you had it first.
2000 AV6 Coupe
- J O N -
Old April 6th, 2004, 11:27 AM   #9
chiefy's Avatar
looks great i love it nice and clean
did u buy it online?
Old April 6th, 2004, 03:35 PM   #10
Nope, I made this mod up on my own. I've actually done it twice now, my first set-up got ruined when someone broke out my rear glass. I'm still finding shards everytime I vaccum out the car...
Mike
Old April 6th, 2004, 03:55 PM   #11
JB4 e92
clean2draccord's Avatar
This is awesome man! I really need to do something about my rear tray REALLY badly. All it ever does is rattle when I drive and/or play my system.
Can you post more details and pictures of the removal of the rear tray?
Thanks!
Old April 8th, 2004, 07:05 PM   #12
Unfortunately I don't have any pics of the procedure, and I don't really want to pull out the tray again...Do you have any specific questions?
Mike
Old April 9th, 2004, 02:42 AM   #13
SILVIA
EuStOn's Avatar
Send a message via AIM to EuStOn Send a message via MSN to EuStOn Send a message via Yahoo to EuStOn
nice!!!!
i was gonna do something like that, but never had a chance to figure out how to take out the rear penal!! if u can share that will be nice!!
good job tho!!
EuStOn is offline   Reply With Quote Quick reply to this message
Old April 9th, 2004, 04:38 AM   #14
SumAznFoo's Avatar
Send a message via AIM to SumAznFoo
Very Nice =D its amazing how creative people are on this site
SumAznFoo is offline   Reply With Quote Quick reply to this message
Old April 10th, 2004, 10:35 PM   #15
Looks OEM . Great job
Old April 11th, 2004, 03:39 PM   #16
That's awesome!
snoopy20 is offline   Reply With Quote Quick reply to this message
Old November 8th, 2005, 06:21 PM   #17
xXxCLS bOoStEdXxX
slowaccord's Avatar
it looks real nice...i want to do something like this since i have a spoler and somehow that third brake light broke and it rattles real hard on the highway....is there a way to just take out the third brake light
Old November 8th, 2005, 06:23 PM   #18
u can, but there will be little holes in that cardboard-like rear tray. may as well re-upholster it, it's not that difficult.
nodoubt is offline   Reply With Quote Quick reply to this message
Old November 8th, 2005, 07:15 PM   #19
I might try some ultrasuede ont deck,pillars,headliner.
wht/accord99v6 is offline   Reply With Quote Quick reply to this message
Old November 8th, 2005, 10:48 PM   #20
4 bangin'
Sketch o5's Avatar
yea man, that looks great.
Old November 8th, 2005, 11:14 PM   #21
Send a message via AIM to SlvrBulletV6
Subtle mod! But makes a huge difference, very clean looking as well! Make this a sticky!
SlvrBulletV6 is offline   Reply With Quote Quick reply to this message
Old November 8th, 2005, 11:49 PM   #22
xXxCLS bOoStEdXxX
slowaccord's Avatar
im getting a seat fixed and will ask if the shop can also do this for me. wat is a good price 2 pay?
Old November 22nd, 2005, 03:46 PM   #23
My car's a pervert too.
Spazzokid's Avatar
I've done something like this, I just modified the rear deck to fit 6.5 spaekers and then recarpeted it. Take a look on my cardomain site listed in my sig. (I'mnot sure how to post pics on here).
Spazzokid is offline   Reply With Quote Quick reply to this message
Old February 6th, 2006, 01:35 PM   #24
I still think this is a pimp mod. It has been almost two years and the vinyl looks as good as the first day I did it. I'm so glad I got rid of that ugly third brake light!
Old February 18th, 2006, 06:35 PM   #25
Boosted!
ComptechV6's Avatar
That looks greatttt
Old February 19th, 2006, 11:38 AM   #26
I thought this PM reply might be helpful. If you have questions please email me...
Originally Posted by vietmandomy52
Hey,
I saw your thread about reupholstering the rear deck and i have a couple of questions.
First how do you remove the non used seatbelt? did you just cut it off?
Also when i try to take the rear deck off how do i take off that plastic piece that surrounds the 3rd brake light? do i just yank it off? Also any techniques in taking off the rear deck? i have to bend the deck a lil bit to get it off the sides right?
Thanks and any tips you have in mind, it would be much appreciated. thanks.
Peter
Peter,
Yes, you do have to cut the seatbelt in order to remove it, and if I remember right, you must remove it in order to do this mod. I never have riders in the back seat, so I haven't missed it at all. If you have small children or often pile your friends in the back seat, I wouldn't do this mod.
The housing for the third brake light has locking "step" tabs that connect it to the sheet metal in the top of the trunk. You should see them when looking up toward the deck from inside your trunk. If you disconnect the light bulb and push the tabs in, the entire assembly will come free.
Getting the rear deck off without screwing it up is the hardest part of the whole thing. Be prepared to order some extra plastic fasteners if you strip the ones on the bottom of the deck. I recommend working it off slowly, side to side. I used a dowel rod to help pop the rearmost fastener out. Once the deck is free, you may have to bow it slightly to get it out, but the leatherette will hide any small creases you create. Whatever you do, don't get impatient and try to force something! While the deck is off, finish any projects that involve the rear speakers or rear window tint; you will have excellent access. Make sure when you reinstall the deck that you completely secure it at all of the fastener points, otherwise you will hear it rattling when you are playing music with lots of bass.
Hope it looks great when you are done!
Mike
