badges - Honda Accord Forum : V6 Performance Accord Forums
Old May 22nd, 2003, 12:32 PM   #1
Must go faster dammit
UrbanVVraith's Avatar
badges
how do i remove the V6 and accord badges, are they just adhered, or rivited like the H ??
and if just stuck on, what should i use to remove 'em?
UrbanVVraith is offline   Reply With Quote Quick reply to this message
Old May 22nd, 2003, 12:36 PM   #2
Senior Member
LaoSiFu's Avatar
Use dental floss then clean it off with products like Simple Green.
Old May 22nd, 2003, 01:01 PM   #3
should i dillute it at all or jus straight?, and thnx BTW
and should i use the mint flavored floss, for that minty fresh clean??
Old May 22nd, 2003, 01:10 PM   #4
Senior Member
LaoSiFu's Avatar
You can just do it straight. Once done just complete it by wasing and cleaning up the junk.
I prefere minty fresh clean. It got the SiFuLao's approval
Old May 22nd, 2003, 10:04 PM   #5
Old Member
Du3ce's Avatar
get some goo gone and a credit card to take off that sticky stuff
Old May 23rd, 2003, 03:24 AM   #6
Yeah just make sure it's not your credit card . I like the H logos on my car so I would never remove them .
Old May 24th, 2003, 05:22 PM   #7
J30A1 => J30A5 => K24Z3
TH23's Avatar
I want to replace the V6 badge with an EX badge. Will Bug and Tar Remover work on the leftover adhesive?
Old May 24th, 2003, 06:07 PM   #8
Senior Moderhater
abram2001's Avatar
Best thing to do is this:
1) Use a hairdryer on hight heat at close range for about 1 minute or two. This will allow the adhesive glue to dry out a little bit.
2) Use strong dental floss, or really soft wire, and slide it behind the emblem. Until you pass through all the way. If need be you can use the string in a "saw" motion, like up and down motion to use the string to gently cut away the glue (dont do this with abrasive wire).
3) Clean up excess glue or residue with a product called "goo one" or other similar adhesive remover. (dont use acetone or other abrasive chemicals that will damage paint surface)
4) Clean area one last time with just regular dishwashin soap and water, and wipe clean.
5) You can leave it as is or go to the next step if you are adding another emblem/decal.
6) Position new emblem/decal with procective covering still on.
7) Once postioned carefully pull away one side of the protective cover, and push it down firmly onto the cars surface, and finish up the rest of the side too in a continue and patient manner.
8) If using a type r emblem, make sure you reset the ecu for the added 18 hp to actually take effect :P
~Abe
Old June 3rd, 2003, 09:28 PM   #9
DV8
Hella Functional
DV8's Avatar
wasn't sure if this was a typo or not, don't use dishwashing soap. It's too harsh for your car. It's proven to strip clear coat and wax.
just use regular car wash soap.
and everything else looks great on this DIY howto. It's pretty much how I did mine too
Function > Form "A show car may not be a race car, but a race car is always a show car."
Old June 4th, 2003, 03:20 AM   #10
thnx guys, jus finished it tonite. looks soo much cleaner,
thnx again for the info.
Old June 4th, 2003, 12:35 PM   #11
SiLvAaCCoRdV6's Avatar
Send a message via AIM to SiLvAaCCoRdV6
hey UrbanVVraith
R u keeping your emblems, if not can I have your "ACCORD" emblem?
SiLvAaCCoRdV6 is offline   Reply With Quote Quick reply to this message
Old June 4th, 2003, 12:50 PM   #12
Senior Member
LaoSiFu's Avatar
Originally posted by SiLvAaCCoRdV6 on June 4th, 2003 at 11:35 AM
hey UrbanVVraith
I may have one. Just remind me for the meeting so I can bring it down.
Old June 4th, 2003, 05:54 PM   #13
steamer
when I took off mine I used a steamer, the kind you use for clothes, it worked really well. I also used goo gone to clean up the rest
meatnpotatoz is offline   Reply With Quote Quick reply to this message
Old June 6th, 2003, 02:49 PM   #14
cool thanks SiFuLao
Old June 12th, 2003, 08:01 PM   #15
i got the black chrome emblems and i think they look great.
i replaced all my silver emblems with them, including the 'ACCORD' emblem
grkguy85 is offline   Reply With Quote Quick reply to this message
Old June 12th, 2003, 08:21 PM   #16
SHARINGAN!
Sentinel's Avatar
Send a message via AIM to Sentinel Send a message via Yahoo to Sentinel
where did u get these at? the dealer charges so much for them =[
Sentinel is offline   Reply With Quote Quick reply to this message
Old June 12th, 2003, 08:42 PM   #17
i got mine from hparts.com for less than 30 shipped.
i think slhondaparts.com has them too
Old November 4th, 2004, 04:30 PM   #18
4.0L
VietNinjaJ30A1's Avatar
What is the part number for the V6 emblem kit in black chrome? Cause www.slhondaparts.com has the "black chrome kit, sedan" and then they have the individual emblems like "Black Chrome, FR, 'H'" and the such. Which one do I get???? =[
