Reverse Glow Gauges - Honda Accord Forum : V6 Performance Accord Forums
Old April 21st, 2004, 09:15 AM   #1
Reverse Glow Gauges
Does anyone have reverse glow gauges?? I tried installing mine and they got stuck on the speedometer and tach, we tried everything to fix it....got any suggestions or opinions??
hondagirlie is offline   Reply With Quote Quick reply to this message
Old April 21st, 2004, 09:42 AM   #2
Yup I have mine installed. I had a problem like that before. All fixed.
snoopy20 is offline   Reply With Quote Quick reply to this message
Old April 21st, 2004, 09:57 AM   #3
How did u fix it???
Old April 21st, 2004, 10:08 AM   #4
check pm
Old April 21st, 2004, 10:51 AM   #5
Old Member
Du3ce's Avatar
either use the fork method or use some glue stick under ur gauges
Old April 21st, 2004, 01:51 PM   #6
Has anyone had a problem with them causing the tach and speedometer to stick?? If so, how did u fix the prob??
Old April 21st, 2004, 02:13 PM   #7
___
borinka99's Avatar
^ search for the "fork method"
Basically, you take a fork (with 4 prongs) and put the 2 middle prongs under the base of the needle and push down on the handle VERY VERY SLOWLY and go step by step, little by little (to make sure it doesn't pop off) and eventually, it shouldn't stick
Also, double-sided take on the back of the gauges themselves will help
borinka99 is offline   Reply With Quote Quick reply to this message
Old April 21st, 2004, 03:06 PM   #8
I never used the fork cause you really can't "feel" I just use my hands and fingers because I can adjust tension.
Old April 21st, 2004, 09:00 PM   #9
all i did was use double sided tape. take some guess and check but after a lil bit you get it to work.
accordv6perform is offline   Reply With Quote Quick reply to this message
Old April 21st, 2004, 09:36 PM   #10
question for original poster: How did you attach the gauges? I have seen many methods from the double sided tape (which was my first feeble attempt) to super glue. At the end, I used photo glue...it's stuff that you use with photos when putting into scrap books and when it comes time to trade in or sell your ride, you can take off the guages. works awesome.
