How Remove GLOW GAUGES? - Honda Accord Forum : V6 Performance Accord Forums
Old May 12th, 2004, 01:00 PM   #1
sittin low
AcCoRd16's Avatar
I glue mine with elmer's glue( the kind that kids use at school). Is it possible to take the glow gauge out without tearing the number on the oem gauge.
Please help ME
AcCoRd16 is offline   Reply With Quote Quick reply to this message
Old May 12th, 2004, 01:02 PM   #2
lucky me, mine is sitting well with just paper glue. so it will be easy to take off.
Old May 12th, 2004, 01:23 PM   #3
sittin low
AcCoRd16's Avatar
Isn't Elmer's glue paper glue?
Old May 12th, 2004, 01:42 PM   #4
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
Elmer's will dissolve in water...... don't know if that'll help in any way though.
Old May 12th, 2004, 01:48 PM   #5
Your V12, My V-twin.
JonHsiung's Avatar
you probably won't tear it, but you'll leave some residue.
if you start going over it with nail polish remover, you'll take off the numbers. so don't do that. take it from me. i no longer have D1 or D2... :X
2000 AV6 Coupe
- J O N -
Old May 12th, 2004, 02:30 PM   #6
Senior Moderhater
abram2001's Avatar
Well first use a hair dryer at close range for about 1.5 minutes. And the glue will begin to loosen, once you remove the gauge you can whipe up most of the glue with a lint free towel, use some goo gone, or nail polish remover to clean it up.
Old May 12th, 2004, 04:11 PM   #7
sittin low
AcCoRd16's Avatar
Thanks
Old May 12th, 2004, 04:44 PM   #8
well at least yours isnt super glued like mines
Old May 12th, 2004, 05:13 PM   #9
Senior Member
driven's Avatar
that stuff melts through plastic.. can even damage glass..
Old May 12th, 2004, 05:44 PM   #10
Old Member
Du3ce's Avatar
yeah im a dumbass i used super glue on mine
Old May 12th, 2004, 06:03 PM   #11
Senior Member
driven's Avatar
well atleast you can get a new cluster if you ever need one for a couple hundred bucks.. not the end of the world
Old May 12th, 2004, 06:32 PM   #12
Old Member
Du3ce's Avatar
i dont think i will sell my car though, might pass it onto my sister
Old May 12th, 2004, 06:40 PM   #13
♠ 2009 Pontiac Vibe GT ♠
lowincash's Avatar
Send a message via AIM to lowincash Send a message via MSN to lowincash
i superglued mine and when i removed it...it left a shiny mark on my gauge =/
lowincash is offline   Reply With Quote Quick reply to this message
Old May 12th, 2004, 06:45 PM   #14
Loneryder
docfnky's Avatar
Send a message via AIM to docfnky
to remove just pull up on the guages and as for removing the glue use some water first and later come back with wd40 to remove any sticky residues.
docfnky is offline   Reply With Quote Quick reply to this message
Old May 12th, 2004, 06:47 PM   #15
sittin low
AcCoRd16's Avatar
WD-40? are you sure it won't leave anything? Have u done this before?
Old May 12th, 2004, 07:36 PM   #16
goo gone will remove some ahesive it sould work
