How to clear the amber from your tail lights (01-02 sedans) - Honda Accord Forum : V6 Performance Accord Forums
Old May 19th, 2004, 12:56 PM   #1
Untitled
VanyDotK's Avatar
Send a message via AIM to VanyDotK
Somebody PMed me and asked me how to do this so I'll just post directions here.
Keywords: cleared, tail light, removed, remove, take out, amber
It's pretty easy. All you do is preheat your oven to 300 degrees, once it's heated to 300 degrees, TURN OFF YOUR OVEN! Make sure you take out all the bulbs from your tail lights and that black foamy protective thing too. On the driver side there is also a box type thing, take that out too. Stick your tail lights in the oven for about 15 mins, pull them out (watch out, they'll be hot) and pry it open real quick (don't open it all the way, just enough so you can stick your hand in there and pull out the amber piece) with a flat head screw driver of some sort and pull out the amber piece then close it up right after, then reinstall, and you're finished. Another way of doing it is to actually break the amber piece while it's still inside the tail light and take out all the broken pieces through the bulb hole. But I wouldn't reccomend that.
recap:
1. preheat oven to 300 degreess
2. take out light bulbs from tail light
3. TURN OFF OVEN (THIS IS VERY IMPORTANT!)
4. put your tail light inside the oven for 15 mins
5. take it out and pry it apart (just enough so you can stick your hand in and pull the amber out) and take off amber piece
6. push it back together as soon as you take out the amber
7. put bulbs back in
8. re-install.
No extra silicone is needed if done right.
VanyDotK is offline   Reply With Quote Quick reply to this message
Old May 19th, 2004, 01:07 PM   #2
Old Member
Du3ce's Avatar
i just did this recently except i only pulled half of the tail light open then i just take a stick go through the other side and poke the amber piece out took me about 30 mins for both.
heres the end result
before:
after:
Old May 19th, 2004, 02:16 PM   #3
EX-Featured Ride Coord.
DaBenz7898's Avatar
Send a message via AIM to DaBenz7898 Send a message via MSN to DaBenz7898
looking good....i wish i did that w/my stockers
DaBenz7898
Pics, mods, and latest updates:
** Click
** Click
DaBenz7898 is offline   Reply With Quote Quick reply to this message
Old May 19th, 2004, 05:00 PM   #4
in love with gold
frozen's Avatar
Send a message via AIM to frozen
i see x's... and does anyone know the pink part on the 98-00 sedans?? is the pink a part of teh plastic??
frozen is offline   Reply With Quote Quick reply to this message
Old May 19th, 2004, 05:11 PM   #5
Old Member
Du3ce's Avatar
yes u will have to buy red clears
Old May 19th, 2004, 06:29 PM   #6
I'm saving up for some Red/CLEARs... CAN"T WAIT TO GET THEM=)
Vtech1213 is offline   Reply With Quote Quick reply to this message
Old May 20th, 2004, 02:06 AM   #7
in love with gold
frozen's Avatar
bleh such a waste, i jus need the inner reverse pieces too.. i made my signals red.
