anyone with oem coupe door sills? - Honda Accord Forum : V6 Performance Accord Forums
Old May 26th, 2004, 08:17 PM   #1
"Keep It Sleazy"
fluidjay's Avatar
I just got the last pair of oem honda coupe door sills from handa and they have plastic pieces glued to the bottom of the sill.Is this for strength during packaging and shipping because the instructions mention nothing about these pieces they are glued all the way along the sill. It looks like when you have to install the plastic clips these clear plastic pieces would get in the way? If you have an 01-02 coupe and have installed these on the upper part of the plastic moulding beside your seat where the carpet meets the door sill can you tell me how you did it?
fluidjay is offline   Reply With Quote Quick reply to this message
Old May 26th, 2004, 10:37 PM   #2
V Go SoCal Drivers V
bustedryde's Avatar
Grind/dremel/remove everything under the sill, including the studs. I used a rotary tool myself. You don't need instructions at all if you're doing it on the runner.
Old May 26th, 2004, 10:56 PM   #3
Hatin' on me hatin' on me
inspired1's Avatar
interesting sills. My sedan sills are only held on by double sided tape
inspired1 is offline   Reply With Quote Quick reply to this message
