DIY: G2 Caliper Paint (Red) - Honda Accord Forum : V6 Performance Accord Forums
Old May 30th, 2004, 10:17 PM   #1
The mod was a very easy one. If you can remove your tires, then you can do it. Did this one with Connie (AlohaBaby) and she said it was pretty easy. Please use this post at your own discretion, I can not be responsible for damages caused.
Time needed: Approx 2-3 hours depending on how many jacks you have. I used my stock plus an extra one i bought for adjusting my TEIN. If you can get the whole car up at once, then it will take a lot less time.
Materials Needed:
1) G2 Caliper Paint Kit (Ebay)
Includes:
a) Paint
b) Reactor Solution
c) Caliper cleaner and tube
d) Popsicle stick
e) Paint brush
f) Instructions
2) Extra brushes - Get different sizes for hard to reach places.
3) Newspaper- To avoid dripping on your garage floor.
4) Extra jack
5) Flat head screw driver
6) Stock jack, wheel lock key
Instructions
1) Break lug nuts before raising car on jacks.
2) Raise car and remove lugs/wheels.
3) Clean calipers using included caliper cleaner. I used sandpaper to sand the surfaces so as to get a smooth finish afterwards.
Front
Rear
4) After cleaning, open paint can using flat head screw driver.
5) Add reactor solution to the paint and mix using popsicle stick.
6) Start painting in thin coats to avoid build up. Avoid paint on the brake pads, rotor, and rubber parts.
(No that's not my hand)
Swerve is offline   Reply With Quote Quick reply to this message
Old May 30th, 2004, 10:32 PM   #2
Coat 1
Front
Rear
Coat 2
Front
Rear
Coat 3
Rear
Otherside Done
Front
Rear
7) Replace wheels/lug nuts. Lower car and repeat on the otherside. The instructions say to wait 2 hours before replacing wheel but I did it after 15 minutes. The only drawback is minor dripping (1-2 drops) of the paint on the inside of my rims. I can just clean that out next time I rotate tires. The reason that I hurried is because the paint only has a lifetime of 4-6 hours depending on the temp (58-70 degrees). I didn't want it to harden before I finished.
Old May 30th, 2004, 10:37 PM   #3
Finished Pictures
Front
Rear
Thoughts
1) Yes it's a ricey mod but I like it and plus since I can't afford a big brake conversion YET, this will have to do.
2) Having a helper was KEY. Thanks to Connie for all the detailing.
3) Will try to take more pics during the day if it doesn't rain in the next few days.
Old May 30th, 2004, 10:55 PM   #4
ponickka's Avatar
wouldn't it be more easy or convienant if u took out the calipers instead??
cuz u're also risking of puttin paint on brake pads/ rotors..just my .02
bump for DIY
ponickka is offline   Reply With Quote Quick reply to this message
Old May 30th, 2004, 11:39 PM   #5
Honda luv
flytojungho's Avatar
Send a message via AIM to flytojungho
yeah, you should have taken off the calipers and pads.. it's not that hard to take it off and it'll look alot better with no paint on other parts.. looks good though..
flytojungho is offline   Reply With Quote Quick reply to this message
Old May 30th, 2004, 11:41 PM   #6
yeah but i think that would've taken longer to remove and then reinstall. i actually got a little on the rotors but i figure that it'll just get rubbed off in a few days. as for the pads, i'll be changing those soon enough so that didn't matter either.
but for those that are truely an al about it...you can always mask off areas. however, if you just get a different size brushes and have a little patience...it'll be okay.
thanks for the comments though.
Old May 31st, 2004, 12:50 AM   #7
fairly easy install to help out with!! unfortunately, my back is a little sore from leaning over (3 hrs) to detail the paint.
but doesn't it look nice?! yay! we did it!!
AlohaBaby is offline   Reply With Quote Quick reply to this message
Old May 31st, 2004, 02:55 AM   #8
Nice brake rotors...brembo right?
and what brake pads u use with them?
AccordiO is offline   Reply With Quote Quick reply to this message
Old May 31st, 2004, 11:59 AM   #9
stock....so far i've heard complaints about all the others in terms of dusting and noise.
Old June 4th, 2004, 06:54 PM   #10
Yeah i think ill do it this way, i got a little skills with a brush, and i cant be bothered to take em off. thanks
Old June 7th, 2004, 12:45 PM   #11
So what's the life of the paint (applied to calipers) in terms of hours or miles? Just curious...
Of all the Smilies, I think this one describes me best, loll
Landshark is offline   Reply With Quote Quick reply to this message
Old June 7th, 2004, 12:48 PM   #12
i think that depends on your climate, if its cold a lot and then you go warming them calipers up then coling them, then warming them up, the paint will flake off a lot quicker then say a guy thats in Florida. ive seen them last as long as 6 or so months, and ive seen some fade in as littel as 6 or so weeks, but i doubt that guy was using the right kind of paint.
Old June 7th, 2004, 01:47 PM   #13
i saw Francis' and he done his a while ago and they still look okay;.
Old June 14th, 2004, 01:47 PM   #14
Hey where did you gys buy this G2 paint, do autozone and those types sell it
Old June 14th, 2004, 01:59 PM   #15
AV6.com Veteran
nice job! i did mine in black
kayotik is offline   Reply With Quote Quick reply to this message
Old June 14th, 2004, 02:00 PM   #16
Old June 14th, 2004, 03:00 PM   #17
ebay
Old June 14th, 2004, 05:39 PM   #18
first pic looks like you got jacked they came out good
Old June 14th, 2004, 09:05 PM   #19
hahah- thanks! sent your flyers today
Old June 14th, 2004, 09:23 PM   #20
Good job! It looks good! I did mine in black. Pics here: (It is much easier to take the calipers off IMO)
http://www.v6performance.net/forums/...threadid=27367
G2 caliper paint is guaranteed for life.
eBay has the cheapers prices that I have seen
Entcee is offline   Reply With Quote Quick reply to this message
Old June 15th, 2004, 05:44 AM   #21
Thanks guys.
