need help - Honda Accord Forum : V6 Performance Accord Forums
Old May 27th, 2003, 05:31 PM   #1
hmmm...
need help
if i have 2 subs at 1000 watts rms, and i plan to get some speakers that need an amp to power them, should i get one amp and how many channels fo i need or get 2 amps?
Old May 27th, 2003, 05:53 PM   #2
Old Member
Du3ce's Avatar
There's a 5 channel amp out, you could power ur 2 subs and 3 of ur speakers. If u want to power all of ur speakers then i suggest u get a 4 channel amp.
2007 Accord EX-L V6
Old May 27th, 2003, 07:07 PM   #3
hmmm...
ur saying get a 4 channel amp.....2 channels for the 2 subs and 2 channels for the speakers?
Old May 27th, 2003, 07:13 PM   #4
Old Member
Du3ce's Avatar
no i meant get another 4 channel amp for ur speakers and have a seperate amp for ur subs
Old May 27th, 2003, 07:14 PM   #5
Re: need help
Ask yourself 2 questions:
One how often do I use the FADER?
And how often do you use the BALANCE?
My guess is that you will use the FADER more than the BALANCE (as I do). I have a 2 channel amp running 6 speakers. I had to run a special adapter as I do not have a head unit yet. The way I wired it was to run both rear speakers to one channel and the front 4 (tweeters and mids) to the other. This allows control of the front and rear control but will not allow the right/left/front/rear control.
Then you can run a seperate 2 channel BRIDGEABLE amp to run any subs.
Old May 28th, 2003, 07:13 AM   #6
To the above guy's post. WHat are you using for your HU? Diskman, md player, etc?
You're sound system's Left Right stereo is being fed Front.. back.
All 4 speakers in the front are all playing the "Left" side and the rear speakers are playing the "Right" side. That makes for a odd soundstage. But anyways...
To the original thread owner... dont get a 5 channel amp... no 5 channel amp will be able to produce 1000 watts mono for your subs.. Get 2 amps and keep it simple. Run a good clean RMS 4 channel amp to run the interior speakers, and either a 2 channel bridged or mono amp to run your sub setup.
WHat speakers are your subs and what speakers are you planning for your interior? What's your budget? This is all going into a 4 door sedan or coupe?
Old May 28th, 2003, 08:09 AM   #7
I am running the OEM CD player. No HU yet.
Yes you are correct in saying that on the CD player the "BALANCE" knob controls the front/rear FADE.
How does this make for an 'odd soundstage'? I have never used the balance control on any stereo I have ever owned. Going right/left with the sound doesn't do anything but make everything quieter. The front/rear control allows me to put more or less of the POWER to the speaker SETS. I have higher powered seperates up front, and not as powerful 6x9's on the shelf.
Old May 28th, 2003, 08:29 AM   #8
Old Member
Du3ce's Avatar
i just got a Panasonic MP3/WMA player 350 bucks
Old May 28th, 2003, 09:16 AM   #9
hmmm...
i think i will go for an amp for the subs and get a separate amp for the speakers when i get them.... my budget is about 600. i already got the subs...
