Quick Help!! Underhood Wire Upgrade - Honda Accord Forum : V6 Performance Accord Forums
Old May 27th, 2003, 08:52 PM   #1
hi, i'm currently running a very mild system...
one typeR with alpine mrp350 amp...
my lights dim slightly when i'm at the stop...
i decided to upgrade my underhood wires...
can anybody inform me which wire i should upgrade??
should be the ground wires that go out from the negative
terminal...right???
any help will be appreciated...
thanx...
ohsik83 is offline   Reply With Quote Quick reply to this message
Old May 27th, 2003, 09:07 PM   #2
Senior Moderhater
abram2001's Avatar
you should just get a cap.
Old May 27th, 2003, 09:15 PM   #3
i'm nowhere near an expert in this audio thing...
i did hear ppl saying the cap will not help any dimming...
it will put even more stress on my charging system...
from wat i heard...the cap might help the sound quality...
like quick notes...i could be wrong...
thanx for givin an advise tho...
anyone else who has done upgrading the wires???
Old May 27th, 2003, 09:27 PM   #4
PitchBlk, aka BigLou 7
Loulax07's Avatar
i dont think its a wire issue bro
keep askin around
maybe higher current battery? optima?
your lights r dimming b/c power is bein taken from them and going to the amp....
Old May 27th, 2003, 09:28 PM   #5
J32A2 6-Speed Rocks
Silv_Accord_V6's Avatar
Send a message via AIM to Silv_Accord_V6
get a high output alternator.
www.4alterstart.com
Silv_Accord_V6 is offline   Reply With Quote Quick reply to this message
Old May 27th, 2003, 09:31 PM   #6
J32A2 6-Speed Rocks
or more specifically
http://www.4alterstart.com/pages/sto...putalternators
damn the price for this alternator went up like crazy.
when I bought it, it was around 180 dollars. Now it's 250 bucks.
SH*T !!
Old May 27th, 2003, 09:39 PM   #7
thanx...
yeah...i know the alternator would definitely help...
as u can see...i got a very mild system...with slight dimming
so i was kinda looking for some alternative...
other than spending big $$$...
i'd like to try all i could to eliminate
the dimming before i end up buying new alt.
so upgrding the ground wire is not gonna do any good then??
Old May 28th, 2003, 07:01 AM   #8
Upgrading your three magic wires will not help you in this situation. Changing the gauge of the wire will decrease resistance of the current, but it will not increase the amount of current... it DOES give you the potential for running more current (via higher output alt..etc) But before you spend big money on a higher output alternator. I'd say get a 1/2farad cap installed, the slight dimming on bass peaks will be quelled.
If you have major dimming, then you'll haveto invest in a good quality alt. You will only need to upgrade your battery if you want to play your system with the car not running.
Dimming occurs when amp draw exceeds the output of your alternator and rest of the power is being drawn from the battery(hence the dimming--electrical supply to rest of car has been comrimised as a result).
I'm usually against caps because IMO they do little to help with major dimming...and ppl swear by them LOL... but in your case spend that extra $75-100 and get one.
Old May 28th, 2003, 10:26 AM   #9
thanx...i'll try dat then...
Old June 19th, 2003, 11:08 PM   #10
if you need an alternator lemme know the details on your car and i can hook you up cheap as hell cause my dad sells them for a living
EnduroExpertFSR is offline   Reply With Quote Quick reply to this message
Old June 20th, 2003, 06:57 PM   #11
what size power wire are you running to the amp? how long? how long is your ground wire? fuse rating?
i see that your amp does 350 watts.. you should have no problems with the lights dimming. the stock alternator should handle it just fine.
i say go get a 4gauge wiring kit if you dont have it already.. make the power and ground wires as short as possible. get a fuse about 40amp and you'll be fine.
vtridah is offline   Reply With Quote Quick reply to this message
Old June 20th, 2003, 08:32 PM   #12
thanks guys...
i just upgraded all the underhood wires to 4 guage...
and i think i used 8 gueage wiring kit for the amp...but...
if i turn on the signal lights at the stop, only the light behind the little clock dims no matter my system's on or off...not my head light, not the whole dash, no nothing....just the damn clock...above the head unit...
is dat normal for our car???
other than dat...seems like the dimming has been
minimized by just upgrading the ground wires...
and i also try to keep the volume low when ma car's not running...
thanks...
daniel
Old June 21st, 2003, 01:34 AM   #13
get a new battery alternator and cap and turn the radio off when the cars off this will help
Old June 21st, 2003, 11:20 PM   #14
the cap definately helps.. i used to have 3 in my car... now just 2. but i installed my cap(s) at the same time as eveything else and no headlight dimming or anything. your headlights should really only dim when you hit a real deep bass note or sumptin.. when your subs are requiring a lot of power to make that deep bass. but otherwise i just got a red optima i can finally run my car stereo longer than about 10 minutes. without having my battery go dead. i got stock alternator still a cap runs about 75 dollars or so.. 100+ for one w/ a digital volt meter.
Myk01Accord is offline   Reply With Quote Quick reply to this message
