Did anyone purchase these bulbs? - Honda Accord Forum : V6 Performance Accord Forums
Old May 30th, 2003, 02:14 PM   #1
I was looking at their website and noticed that there is a instrument bulb that looks like this:
Here is the description:
T1.5 Instrument Lamp
1-LED Instrument Cluster and Gage illumination bulb. T 1 1/2 bulb installed in twist-lock socket base Available with White, Blue, Green, and Red wide angle LED
$ 1.79
Does anybody know if this will fit our car. Anybody order these bulbs from them? I would really like to change the odometer and clock bulbs.
Here is their website:
http://www.superbrightleds.com/cgi-b...gi?product=CAR
I emailed them but they did not know.
02accordSE is offline   Reply With Quote Quick reply to this message
Old May 30th, 2003, 03:32 PM   #2
Old Member
Du3ce's Avatar
i think those are 198/164 bulbs and it's use to light up the 3 needles for the gauges.
2007 Accord EX-L V6
Old May 30th, 2003, 03:40 PM   #3
The ones you are talking about are these:
WLED-W White LED bulb
12V White 1-LED Wedge Base Bulb
$ 1.49
Old May 30th, 2003, 06:17 PM   #4
Old Member
Du3ce's Avatar
i guess its the little bulbs then i think it'll work
Old June 5th, 2003, 12:58 AM   #5
those LEDS with the wedge bases(198/164) fit our accords, right?
i mean for lights in the center panel.
i3lue33 is offline   Reply With Quote Quick reply to this message
Old June 5th, 2003, 08:41 AM   #6
Old Member
Du3ce's Avatar
yep
Old June 5th, 2003, 09:17 AM   #7
If you want to put LEDs in your gauge cluster you'd have to use the first one. The 2nd picture are the same bulbs, but in a difference base. The 2nd one are the bulbs you can put in your door light, or the parking light up front.
loxllxol is offline   Reply With Quote Quick reply to this message
Old June 5th, 2003, 09:27 AM   #8
Old Member
Du3ce's Avatar
there are also a 194/168 bulbs used in the gauge cluster there is 3 of them for the 3 needles.
Old June 5th, 2003, 10:09 PM   #9
DV8
Hella Functional
DV8's Avatar
whoa whoa whoa,
so the twist in T1.5 LED bulbs are the direct swap in for the clock light bulbs? and the instrument cluster bulbs???
that's ****ing AWSOME!
Function > Form "A show car may not be a race car, but a race car is always a show car."
Old June 5th, 2003, 11:58 PM   #10
Originally posted by DV8 on June 5th, 2003 at 11:09 PM
whoa whoa whoa,
That is what I want to know.
Old June 6th, 2003, 08:19 AM   #11
DV8
Hella Functional
DV8's Avatar
i guess someone buy one and try it out, it's only 2 bucks
Old June 6th, 2003, 09:19 AM   #12
Yeah but shipping is $5 so it would only be a good idea if someone was going to buy some other LEDs like 1157s or 168/194s. Since shipping does not change when you order more bulbs.
Old June 6th, 2003, 01:08 PM   #13
No, No, No, this LED will only fit the automatic shifter (on the floor) the dometer in the gauge cluster, and the 4cyl temp gauge in the cluster.
The gauge cluster bulbs for the V6 and 4cyl (except the temp gauge) use size 194/168
The clock, climate control end everything else still have to be modded to get an LED to work. You must solder resistors on the LED's in the stock bulb holders. (My site has all the instructions.)
These are in direct competition to the ones that I sell, so I purchased a couple. All I can say is these are not bright enough at all. Mine are WAY brighter. Yes, mine are $8, but you get free shipping (1st class mail), and you are sure to get very bright LED's. They will also match the LED kits that I sell perfectly.
There is a reason they are so cheap. Even NetDisty sells the same size, but theirs are $11 each.
visit www.99Accord.com for more info.
Entcee is offline   Reply With Quote Quick reply to this message
Old June 6th, 2003, 03:06 PM   #14
Senior Member
aCcOrDv6VTEC3R's Avatar
i have those. alot of them like 20. they are not that birght
Old June 16th, 2003, 09:35 AM   #15
Everyone!
the twist-lock T1 1.5 LED bulb WILL NOT fit the clock bulb! The clock bulb does have the same twist-lock base but it is smaller, way smaller. You will need a 3mm peanut size bulb to fit it. The twist-lock T1 1/2 LED bulb can fit our cars but only in the A/C control panel. I know for a fact that the left and right dial on each side can fit the twist lock T1 1/2 and the also the LCD readout in the center but the other buttons require a smaller twist lock base, i believe a T1 1/4 bulb. im not exactly sure but the T1 1/2 wont fit the other buttons only the dials and center screen.
i've been searching and searching the net for smaller twist lock LEDs but no luck so if anyone knows please let me know, cuz so far i have two blue dials an orange clock and orange A/C screen.
(they are orange because i took out that nasty green filters behind the screens and the true color is orange, crazy! BLUE and ORANGE, what a combo!) i get definate looks and comments cuz ppl dont really see to often a blue and orange color scheme.
Old June 16th, 2003, 12:39 PM   #16
Post pics because those LED's are not that bright. I would like to see how bright they light up the dials.
Thanks
Old July 9th, 2003, 09:13 AM   #17
$ 1.49
Where did you get that 1.49 price ?
Usul is offline   Reply With Quote Quick reply to this message
Old July 9th, 2003, 09:34 AM   #18
$ 1.49
i bought these and tried them in the dome lights, they came out kinda purple and dim. i also tried the ones with the 4 mini leds before, those came out brighter and more white, still a tint of purple though
HxD Av6 is offline   Reply With Quote Quick reply to this message
Old July 9th, 2003, 10:14 AM   #19
Entcee ... www.trucknvans.com/bulbs/bulbcover.htm
what size did you get for your bulbs for the needles ?
Old July 9th, 2003, 01:46 PM   #20
I got the small ones. I have a different brand (one set) for sell. $7 mailed if anyone is interested.
