Amp control : on/off? - Honda Accord Forum : V6 Performance Accord Forums
Old May 31st, 2003, 12:43 PM   #1
I have a Alpine 7875 HU, 750watt Pioneer Amp, and two Jensen subs.
There is no amp controller wire on my wiring harness so the amp will always stay on. Can I use the power antenna wire or another wire labled IN INT for the controller?
Synthetic599 is offline   Reply With Quote Quick reply to this message
Old May 31st, 2003, 12:48 PM   #2
What Da Pho*?
bachviet's Avatar
Send a message via ICQ to bachviet Send a message via AIM to bachviet Send a message via MSN to bachviet Send a message via Yahoo to bachviet
Don't use the power antenna wire because your amp will only turn on whenever you listen to the AM/FM radio.
'00 SS AV6 EX Sedan&mpt=[CACHEBUSTER]">
bachviet is offline   Reply With Quote Quick reply to this message
Old May 31st, 2003, 12:49 PM   #3
the remote wire on the amp is what controls when the amp turns on or off....that wire should be connected to a power source that only comes on when the car is on.
Old May 31st, 2003, 01:24 PM   #4
PitchBlk, aka BigLou 7
Loulax07's Avatar
all else fails, get a toggle switch for your power wire....
just turn it on when u want
Old May 31st, 2003, 02:08 PM   #5
Thanks guys but I ran into new problems. Forgot I could not use the older Honda HU harness so I had to order the new one.
Old May 31st, 2003, 03:03 PM   #6
Loulax07's Avatar
u will need an adapter harness, to go from OEM to a generic.... (so u dont cut and splice the OEM wires)
metra makes one
Old May 31st, 2003, 03:32 PM   #7
Actually I ordered the one you said to get from Audio Out Fitter.
Actually used the search function and ya know what? It works!
Old June 1st, 2003, 05:20 PM   #8
most aftermarker hu have a remote wire output, dat controls when the amp turning on/off.
if not, get a switch and done
matador is offline   Reply With Quote Quick reply to this message
