SRS light on, not fuse though? HELP - Honda Accord Forum : V6 Performance Accord Forums
Old June 1st, 2003, 05:32 PM   #1
well with all of the accord savvy people here, i have managed to replace my clock bulb with no hesitation. now the SRS light will not go off on my gauge lights. any help on this would be much appreciated. i checked the number 2 fuse on the drivers side(10 amp), and it was fine with no signs of it being a bad fuse.
Mateo is offline   Reply With Quote Quick reply to this message
Old June 16th, 2003, 06:16 AM   #2
search "srs light", there are quite a few posts on this.
Old June 16th, 2003, 11:10 AM   #3
have u had emissions/ inspection lately...when you get ur car tested ur srs light will turn on for a short while....or maybe there is a possibiliy something is wrong with your supplemental restraint system.....i know thats a weird idea huh?.......jp
Midnight Heretic is offline   Reply With Quote Quick reply to this message
Old June 16th, 2003, 11:19 AM   #4
Senior Member
LaoSiFu's Avatar
To reset the SRS light, here are the cliff notes -
1. bend a paper clip into a 'U' shape to create a loop
2. disconnect the yellow plug in your fuse box under the steering wheel and insert the paperclip into the plug that is now hanging there to complete the circuit
3. turn the ignition on and the SRS light will stay on for 6 seconds, then go off - disconnect the paperclip within 4 seconds after that and the light will come back on
4. reconnect the paperclip within 4 seconds and the SRS light will go off again
5. within another 4 seconds of it going off, disconnect the paperclip and the light will blink twice and it will be done
In regards to Tein products, PM honda_girrrl.
