Bright blinker mod - Honda Accord Forum : V6 Performance Accord Forums
Old June 3rd, 2003, 01:56 PM   #1
Lightbulb Bright blinker mod
I thought I would share some of this information with my friends.
I have recently changed the bulbs of my turning signals to Polarg M12 bulbs and was very very disappointed with how they looked when they were dim. As a result I did a complete overhaul with my blinkers. They stay on bright and also I can control the speed at which they blink.
There used to be a how to page but it does not work anymore so I'll give you mine home made instructions.
But first here are some pics.
This is a DYI mod so do it at your own risk. Not responsible for anything that may go wrong but will be happy to answer any questions.
Here is the wiring.
All you need is basically two SPDT relays which you can buy from Ebay for like $6 shipped. Here is a link to where I got mine:
Ebay Link
Quick instructions:
Cut all three wires. Connect the red wire from the car to to 87a on the relay and the green wire from the bulb socket to 30 on the relay. Next take the green wire from the car and connect it with the red wire from the bulb socket and connect both of them to 86 on the relay. Connect both of the ground wires to 85 on the relay.
This is an awesome mod if you have LED bulbs. I also suggest you make an adjustable flasher in order to control the flasher rate. If you have any questions let me know.
02accordSE is offline   Reply With Quote Quick reply to this message
Old June 19th, 2003, 03:07 PM   #2
i sent u a PM...i juast wanted to know does the signal light stay on in the bright position all the time? and when u put your blinker on what happens? does it go from the bright position to an off position? I have the piaa's i like how they look in the bright position( when the signal is on) but not the reg. position(when the signal is off...they seem to dimm)
Satin silver02 is offline   Reply With Quote Quick reply to this message
Old June 19th, 2003, 09:07 PM   #3
is it really that simple? sounds really easy but I'm scared I may mess up something.....also has anyone else tried it this same way and had the same success?
01accrdExV6 is offline   Reply With Quote Quick reply to this message
Old June 20th, 2003, 05:34 AM   #4
The blinker is basically opposite of what it is originally. Instead of dim w/parking lights it is as bright as if the turn signal is on at all times. When the turn signal goes on it blinks bright, dim, bright dim..... Looks really sharp w/hyper blue bulbs. You can probably tape off one of the sides of the bulb to make it blink on and off.
Old June 20th, 2003, 06:14 AM   #5
What about with the parking lights off, does it blink dim, off, dimm, off?
Or does it blink bright, off, bright, off?
Thanks
Entcee is offline   Reply With Quote Quick reply to this message
Old June 20th, 2003, 07:18 AM   #6
that looks like a SWEEET mod, especially since my PIAA signals will match my Sylvanias perfect when they are bright. when u say make an adjustable flash control....how? i guess that means after you do this mod, you are stuck with hiper blinkers?
Old August 6th, 2003, 06:13 PM   #7
This is funny- I just bought the Polarg M14's for the corner, put em in, and I was pissed as hell. I've been thinkin about how to do what u guys are talkin about for a few days, then I figured I'd check on here. Sure enough, everyone else is tryin to figure it out. ANYWAY- question- I bought the PIAA 1157 bulbs, figuring they might look the way I want.... will they look any diff than the Polargs? Or should I just cancel the order right now?
pastaVTEC is offline   Reply With Quote Quick reply to this message
Old August 27th, 2003, 12:58 AM   #8
He Is The Fu<king Master
WICKEDFX's Avatar
Send a message via AIM to WICKEDFX Send a message via Yahoo to WICKEDFX
Thanks
The lights will flash bright---off, when they are turned off. but when the parking lights or headlights are on, you most likely won't even see it flash due to the high filament staying on bright all the time, when the dim one flashes it's not bright enough to see with the other filament. but if you want an easier way to do this, just get a very small thin flathead screwdriver (ones made for sunglasses and stuff) then stick in the blinker harness and release one of the wires. then do the same to the other wire, and just switch their positions in the harness. leave the ground wire the same.
http://members.cardomain.com/wickedfx
It's supposed to be a challenge..... that's why they call it a shortcut. If it was easy then it would just be the way!(roadtrip)
WICKEDFX is offline   Reply With Quote Quick reply to this message
Old August 27th, 2003, 05:57 AM   #9
If you use the relay it blinks bright, dim, bright, dim.............and stays bright after you turn off your blinker (that is if you have your parking lights on)
Without parking lights on it blinks bright, dim, bright, dim.............. and stays off when you turn your turning signal off.
Old August 27th, 2003, 10:09 PM   #10
Send a message via ICQ to Redline Send a message via AIM to Redline
Just tape off one of the connectors on the bottom of the bulb, this will give you turn signals -only- when you're turning, but they are off->bright->off. So essentially your running lights will be the only thing on one click up and the headlights/running lights with two clicks. The turn signal just lies dormant till you need to turn.
Redline is offline   Reply With Quote Quick reply to this message
Old September 1st, 2003, 04:22 AM   #11
V6 -> I4 -> I6
HwaNi.J30A-C's Avatar
can you explain how to slow down these super rice fast blinking crap from LEDs?
Im really getting sick of it. My girl is getting sick of it. My parents hate it. My friends call it ricey. Neighbor looks at me weird, I really need to fix this.
The Ultimate Overpriced Driving Machine: BMW
Previous: 02 Honda Accord V6 / Few mods. RIP.
Old September 1st, 2003, 03:43 PM   #12
Do you have a relay or what?
Old September 2nd, 2003, 06:59 PM   #13
Buy an adjustable flasher on Ebay or make one yourself.
Old September 2nd, 2003, 07:15 PM   #14
V6 -> I4 -> I6
sounds good, thing is, those adjustable flasher is like 30 bucks, which I don't want to spend more than 5 bucks on those rice parts..
do you know any "know-how" to make one?
thanks bro.
Old September 3rd, 2003, 10:53 AM   #15
Just tape the contact on the bulb, you dont have turn signals any time but when you're turning, but it gives the same off/bright effect.
Old September 11th, 2003, 12:13 PM   #16
ayo,how do you make the blinker speed ajuster???
puertoroc719 is offline   Reply With Quote Quick reply to this message
Old September 11th, 2003, 04:39 PM   #17
Take the blinker apart. There should be a little resistor in the right hand corner. You have to take it off and in its place solder a wire to each end. Run the wire to a potentialmeter. You can buy one of these at Radio Shack for like $2. I think 0-300K works best but I could not find one with that resistance so I bought a 0-1000K and it works fine. Hook up the wire to the potentialmeter and adjust it to the speed you want.
You will need to drill a hole through the plastic part of the flasher so that you can run wire to the potentialmeter.
Old September 14th, 2003, 06:39 AM   #18
WICKEDFX's Avatar
So basically what everyone wants to do is be able to turn on your running lights and the parking lights come on bright. Then use your turn signal and have the blinkers flash off-on-off-on so you will be able to see the blinker.................... I'm trying to think how to do this with a duel filament bulb. i know how to on a single filament bulb, but never tried on duel.
i have an idea and i'll let everyone know if it works.
Old September 14th, 2003, 07:54 AM   #19
YES! thats exactly what i want!!!! even if it doesnt work with the 1157, please let us know how to with a 1156!
kkoch is offline   Reply With Quote Quick reply to this message
Old September 15th, 2003, 02:04 AM   #20
If you want your turn signal bulbs to be on all bright, then off/on/off when blinking, the only way to achieve this is with the relays peopl have used before. If you dont want the turn signal bulbs on all the time (how I have them) Just tape off one of the contacts on the bulb itself to get off while the lights are on and full bright/off/bright when signaling.
Old September 15th, 2003, 03:56 PM   #21
The only way to have them stay on bright is by using the relay shown in the beginning of this thread.
Old September 15th, 2003, 04:02 PM   #22
Can you show us how to connect the relay?
How do we know what to connect to what? (even if we use a differend brand of relay.)
Old September 15th, 2003, 11:25 PM   #23
and will this give us hyper blinkers.. cause i dont want hypers....
Old September 16th, 2003, 05:20 PM   #24
All SPDT relays have the same numbers on their terminals 30, 87a, 86, and 85. Make sure the relay you buy has 5 terminals like the one in the picture. One of the terminals is not used.
I am not sure if this makes your blinkers hyperblink because I already had an adjustable blinker installed.
Old September 26th, 2003, 01:15 PM   #25
Here's intrcutions on how to mke your own blinker adjuster
http://www.andrews.edu/~johnsonm/how...erblinker.html
scootrz3 is offline   Reply With Quote Quick reply to this message
Old October 5th, 2003, 06:56 PM   #26
DTB
Very nice idea...
DTB is offline   Reply With Quote Quick reply to this message
Old October 26th, 2003, 07:29 PM   #27
I just used a trailer hitch light converter from Walmart.
Does the same thing this mod does.
Drawback: you do get the double speed blinker
Pros: It gives you bright on all the time
BWatkins is offline   Reply With Quote Quick reply to this message
Old December 4th, 2003, 03:19 PM   #28
i just tried this on my 03 and it doesnt work because the relay used under the dash is made of all microprocessors so that means there is no way to modify it.
ALSO, what kind of amperage should i get for that relay?
03accord03 is offline   Reply With Quote Quick reply to this message
Old December 27th, 2003, 04:18 PM   #29
hey..this is just random..and i dont know if this would mess anything up but..
what if u connected the green wire (the blinkin wire) to the red power wire? wouldnt the bright filament be on all the time getting the constand power from the red wire?
Old January 1st, 2004, 07:09 PM   #30
i tried this when i was doing my little led bulb blinking mod. only to realize that when you signal, the bright blinkers will never shut off and you will not see the dimmer light blinking. you need a relay. i'm sitting here now trying to understand how relays works
here's the diagram if anyone is interested
ok so looking at the diagram, wouldn't it be more correct if the green_bulb wire is connected to 87a and the red_car wire is connected to 30. I know it wouldn't matter in this case, just trying to understand it so I can do other stuff.
2000 Accord V6 EX
Current mods:
ICE: Eclipse 3434 HU, PPI PCX-480 Amp, Apline Type-R Component Front Speakers, MB Quart DTC-169 Rear Speakers, Infinity Basslink Sub
Exterior: 18 Axis TC Evo, Catz 4100K HID, Tenzo 200x Fog Lights, Tint, DIY Black Housing, 01-02 Front and Rear Bumper, Hi Performance Stickers
Interior: DIY Gunmetal dash, Reverse Indiglo Gauges
Suspension: Tein SS Coilovers, CL-S front strut bar, CL-S rear sway bar
Engine: AEM SR, Intake Heat Shield, Magnaflow Catback Exhaust, TL Battery Cover
Near Future mods:
Headers
Pullies
Looking for a job?
http://www.v6performance.net/forums/showthread.php?s=&threadid=17052
