Do you have non OEM Fog Lights?? - Honda Accord Forum : V6 Performance Accord Forums
Old June 3rd, 2003, 06:02 PM   #1
Ok, I'm looking looking to get a set of budget aftermarket fogs for my car, but as i'm perusing thru the selections, i realize that most, if not all, are too tall to fit in my grill. I've got a '98 Sedan front end there's less than 2in. vertical I can work with, more like 45mm. The only places where i can mount it slightly behind the grill is practically to either side of the front license plate mount, real close to the centerline, very "uncool." Do people just mount then infront of the grills or what?
I'd like to avoid cutting into my grill if it isn't absolutely necessary, but how do you guys have it set up and if you managed to do so, what fogs did u use?
and yes, i'm jeleaous or all you 01-02 coupe peps out there...
Spread the knowledge...
I'll be right here!
Hai_c83 is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2003, 06:10 PM   #2
Player Hater
i got a 98 and i have piaa 1100x , i had to cut the grill...
jim-rock is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2003, 06:18 PM   #3
damn
but still hopeful nonetheless...
Old June 3rd, 2003, 07:28 PM   #4
Your V12, My V-twin.
JonHsiung's Avatar
for my bro's bday we riced up my dad's car with some tenzo 500 foglamps. you don't have to cut the grill to put them on, but honestly they look gross in the front. just cut the grill.
2000 AV6 Coupe
- J O N -
Old June 3rd, 2003, 07:55 PM   #5
I got fogs in my rear bumper if it's any consolation...I had to cut the bumper though..
ruM's OUT...
sCM redruM is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2003, 08:46 PM   #6
Why not cut the grill? It's 10 seconds per cut with a hacksaw blade, invisible once you're done and makes no difference in function or durability.
Sam
Sam Lin is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2003, 08:52 PM   #7
I had to cut my grill. So I imagine you have to cut yours also. I think they would stick out way too much. I also have a cool DYI mod for your OEM fog lights.
Click link below:
Link
02accordSE is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2003, 11:37 PM   #8
def gonna try that, but looks like PIAA 1400's, 1700x's, & 002x's won't require grill cuttin'
I've got 2 1/16in. (52.5mm) vertical clearance...
something cheaper avail?
Old June 3rd, 2003, 11:51 PM   #9
cut that grille.....
i did!!!
..i have those ugly tenzo 500's.....i dont like them.....
jonathan.c. is offline   Reply With Quote Quick reply to this message
Old June 4th, 2003, 12:20 AM   #10
JonHsiung's Avatar
haha yeah i dont either. but for some strange reason they're still on my dad's car...
2000 AV6 Coupe
- J O N -
Old June 12th, 2003, 04:13 PM   #11
Hey, i have non oem fogs, they are the 'inexpensive' (cheap) ones you get from a auto parts store. I got the ones that arent shaped like alien eyes but are kind shaped like a track not really an oval but more like a rectangle with rounded corners, they fit in the tiny place between the grill. I mounted them just to the outside of the vertical bracing. So that is just inside of the headlights, but almost under the high beams. Hope this makes sense.
davejax904 is offline   Reply With Quote Quick reply to this message
Old June 12th, 2003, 05:14 PM   #12
hey dave, so what kind of lights do you have? brand? type?
how did you hook them up, was the electical thing infront of the radiator it and how did you wire the fog light's switch?
as of now, the only fogs that'll fit unmodified are PIAA 1400(x), 1700, & 002x. which are really expensive for my budget.
Looking at the dimensions of the fogs above leads me to believe that my Max Vertical Clearance is 2 1/16" (52mm )
I'm basing this on the fact that PIAA 1900's will no fit w/o modification when they are 2 3/16" (55mm)
thanks dude, i appreciate it, this'll aid me plenty
