DVD audio/video help... - Honda Accord Forum : V6 Performance Accord Forums
Old June 4th, 2003, 03:20 AM   #1
___
borinka99's Avatar
OK,
I got this awhile ago and was going to sell it, but now I think I have an idea....
I have this DVD player
and I have a 7" lcd screen that I want to put where the OEM headunit goes after I take that out.
My question is if I will be able to connect everything without having to buy a headunit or if I HAVE to buy an aftermarket headunit.
I talked to the guy that I bought the player and screen from and he said I might be able to do it if I buy an amp to power the stock speakers so that the sound can go from the dvd/mp3/cd player but he doesn't know if it will because might not have a "power on" wire.
Would I be able to do this with an amp or would it just be much better if I bought an aftermarket headunit to run the sound off of?
Thanks for your help
-Boris | Senior Moderator | So Cali Chapter Mod | Random Chatter Mod |
You can never master the game until you realize that it can never be mastered!
How to post pics:
borinka99 is offline   Reply With Quote Quick reply to this message
Old June 4th, 2003, 08:43 AM   #2
You could just keep your stock headunit and plug it into the AUX port.
http://www.logjamelectronics.com/piehonaux.html
99%StockAV6 is offline   Reply With Quote Quick reply to this message
Old June 4th, 2003, 02:28 PM   #3
___
borinka99's Avatar
But then I would have the problem of where to put the stock HU because I want to put the LCD screen where the stock hu goes.
How to post pics:
Old June 4th, 2003, 09:11 PM   #4
Why not create a bracket and put the LCD directly below the stock HU in that pocket thing?
halcyon is offline   Reply With Quote Quick reply to this message
Old June 4th, 2003, 09:37 PM   #5
___
borinka99's Avatar
I have a little thing to put it there but I think I would rather have it up a little higher in the stock HU place. But if I did it this way, would I be able to connect the DVD Player to the Stock HU and the Screen?
How to post pics:
Old June 5th, 2003, 02:14 AM   #6
Yes, you'd have to buy the special wire to adapt to the cd changer output. Where are you going to put the dvd player???Also, you could hook up an amp to the dvd player to get sound if it has a rca outputs, which most likely it does. I would get an aftermarket deck rather than use your factory radio, it would sound a lot better. So many options you can do, have fun choosing.
ricepilof is offline   Reply With Quote Quick reply to this message
Old June 5th, 2003, 03:01 AM   #7
___
borinka99's Avatar
Yea, I think first I'm gonna have to somehow fit the 7" screen into the stock HU's place by dremeling the cover thing and then try to see if this old (piece of ****) headunit I used to have would still work just to get the sound from the DVD player to the speakers and mount that under the stock headunit, then try to put the dvd player either in the glovebox or armrest
How to post pics:
Old June 5th, 2003, 11:37 AM   #8
what you need is an fm modulator to get the sound from the dvd player to come out of your headunit. once you get the dvd sound hooked to the fm modulator, the modulator splits the antenna input from you headunit and feeds the sound to a radio station you don't use. i have an extra one lying around. i can sell it to you for $35 shipped if you interested.
jaybonez99 is offline   Reply With Quote Quick reply to this message
Old June 5th, 2003, 01:27 PM   #9
___
borinka99's Avatar
So If I buy this fm modulator, all I would have to do is connect the DVD player to the modulator to the speakers? I thought the FM modulator was something to connect a cd changer to your car and you would have to turn it to a certain FM station to be able to use it.
How to post pics:
Old June 5th, 2003, 01:39 PM   #10
yes fm modulators are also used for cd changers. basically fm modulators feed sound to any headunit via a radio station if the headunit does not have an rca input. the dvd sound is sent to the fm modulator which sends the sound to your headunit through the radio antenna which is split by the modulator.
