235/40/18 with offset +42mm - Honda Accord Forum : V6 Performance Accord Forums
Old June 12th, 2003, 01:30 AM   #1
i need advice guys... will these rims rub? i'm not currently dropped but i will have some prokits soon so i'm getting kinda worried. they are 18" 235/40/18 lemme know guys!
EnvyJK is offline   Reply With Quote Quick reply to this message
Old June 12th, 2003, 01:09 PM   #2
come on nikkaaaas.. i need help!
Old June 12th, 2003, 02:34 PM   #3
yes!!!!!!!!!unless you get a higher offset or roll the finder.
hkspower is offline   Reply With Quote Quick reply to this message
Old June 13th, 2003, 02:31 PM   #4
are you sure? cuz i'm getting mixed responses... some say that I won't rub at all unless i drop over 2". others say i will definitely rub? i need someone who actually knows for sure or has had experience with the same dimensions... please!
Old June 15th, 2003, 06:36 AM   #5
my rim are 45 offset and I have 225 and I had to roll the rear finder . You have 42 offset with 235 it will rib like crazy. you should have gotten a highter offest you you wanted to go witha bigger tires.
Old June 25th, 2003, 02:10 PM   #6
I have 18x7.5 with 225-40 with a 43mm offset
with a 2.25 inch drop . I RUB all the time
i am afraid to roll my fenders with the bat so i
will probably get coiloversleeves to raise it up ;
in the back. thats is the cheapest option right?
eckodlux is offline   Reply With Quote Quick reply to this message
Old June 30th, 2003, 09:53 PM   #7
would it matter if it was a difference tire size like 215/40/18 or is it just the fact that the offset is too low. im thinking of getting some rims and the dimension on the thing is 215/40/18 +42 offset 18x7.5.. help?!
2005 S2000
2004 545i
lilazngrl4o8 is offline   Reply With Quote Quick reply to this message
Old June 30th, 2003, 09:56 PM   #8
if you were dropped 2 inches, would you still have that rubbing problem? what springs are you using that gives a 2.25 drop anyways?
2005 S2000
2004 545i
Old July 1st, 2003, 03:37 AM   #9
dang...235..thats wide as hell dude..
vtridah is offline   Reply With Quote Quick reply to this message
Old July 1st, 2003, 03:07 PM   #10
ok.. well, i put them on and they don't look too bad... the traction with those tires are crooshul though... but I can tell just by the looks of it that I probably will have some rubbing in the back with those tires... i'll prolly just end up rolling the fenders... i dunno yet
