Yoko's or Conti's - Honda Accord Forum : V6 Performance Accord Forums
Old June 14th, 2003, 03:56 AM   #1
Yoko's or Conti's
Anybody have Yoko AVS ES100's or Conti-extreme contact's? I can't decide between the two. I am looking for a performance 3 season tire and in NH it usually means some snow. Therefore, if I get the Yoko's I'll have to run on snow tires for like 5 months! Do the Conti's perform well, or are the tire-rack reviews written by old farts?
NH-coupe is offline   Reply With Quote Quick reply to this message
Old June 14th, 2003, 07:06 AM   #2
Accord Owner
Yoko AVS ES100's by far the best tires !!
00accord is offline   Reply With Quote Quick reply to this message
Old June 20th, 2003, 07:58 PM   #3
Yeah, go for the Yokohamas AVS ES100.
Vader2k is offline   Reply With Quote Quick reply to this message
Old June 20th, 2003, 08:02 PM   #4
But the answer is Yoko'S!!!!!!!!!
leatherface_ca is offline   Reply With Quote Quick reply to this message
Old July 4th, 2003, 11:59 PM   #5
the continental's suck! my cuz and my aunt have the as OEM tires on there bmws and had to get them replaced within 9000 miles..I whould go with some yoko's or toyo, mich. pilots are good but expensive..
Importeck is offline   Reply With Quote Quick reply to this message
Old July 6th, 2003, 07:10 PM   #6
were they the conti-extreme contacts?
'cause I heard that most conti's suck, but these were the exception.
Old July 6th, 2003, 11:09 PM   #7
What Da Pho*?
bachviet's Avatar
Send a message via ICQ to bachviet Send a message via AIM to bachviet Send a message via MSN to bachviet Send a message via Yahoo to bachviet
Yokohama
'00 SS AV6 EX Sedan&mpt=[CACHEBUSTER]">
bachviet is offline   Reply With Quote Quick reply to this message
Old July 7th, 2003, 01:14 AM   #8
nitto 555 very good tracktion
Old July 7th, 2003, 06:19 PM   #9
get the Yoko's
aznpnoy562 is offline   Reply With Quote Quick reply to this message
Old July 10th, 2003, 11:37 PM   #10
quick question guys is toyo FZ4 tires any good?
Slacker is offline   Reply With Quote Quick reply to this message
Old July 11th, 2003, 05:10 AM   #11
Old July 13th, 2003, 07:03 PM   #12
I have the toyo FZ4's dont really like them. They dont grip that good.
TanG is offline   Reply With Quote Quick reply to this message
Old August 2nd, 2003, 01:57 AM   #13
QuizWORX's Avatar
Does the Yokohama AVS ES100 a quiet tire? Coz' i have the Yokohama Parada, man, they were too noisy! You can actually hear like a grinding sound when you start rolling.
Always consider the noise level of the tire before you buy one. The Parada's has a very good grip on the dry road, but on wet surface they kinda hydroplaning plus the annoying noise.
So before buying tires check every category of the tire: Dry Traction, Wet Traction, Snow Traction, Handling, Ride Comfort, Noise Comfort and Treadwear.
I check the review on the tires, it seems pretty good!
http://www.1010tires.com/tire.asp?ti...odel=AVS+ES100
Injen Intake, Injen Heat Shield, Hayden Transmission Oil Cooler, Denso Iridium Sparkplugs, APEXi WS Cat-back exhaust (single), SPE Helix Throttle Body Spacer, Hyper Ground System, Hyper Voltage System.
Cross-drilled, Eibach Pro-kit Springs, 5Zigen 5ZR 225/40 R18 2pc, Pirelli P-Zero Nero 225/40 R18
Levoc pedal, Razo shift knob, 2002 Accord Head Rest, H.I.D. 10k Headlight, Rosen R6500 Double-DIN DVD/CD/MP3/TV/AM-FM Stereo, NAV Ready
Honda OEM Body kit, Honda OEM Spoiler
QuizWORX is offline   Reply With Quote Quick reply to this message
