Help on interior neon lights!!!! - Honda Accord Forum : V6 Performance Accord Forums
Old June 15th, 2003, 01:32 PM   #1
I need help on installing my neon lights for the interior. What i want to do is have it hooked up to my door sensor switch so my neons only come on when the door is opened and im also wondering if it is the same thing as hooking it up to the interior center dome light that it will be the same thing as it already has a switch on there......if anybody has a how to or can point me in the right direction that would be great....thanx
GQ888 is offline   Reply With Quote Quick reply to this message
Old June 15th, 2003, 07:41 PM   #2
im assuming that your putting neons under you dash you can either wire it to the dome light so when either door is opend they both come on or you can wire it to the each door so when you open the drivers door the diver side neon comes on and when you open the passanger side that side comes on
you can run wires to either the lights it self or find the wires headed in that direction from the fuse box
Old June 16th, 2003, 11:13 AM   #3
i know this is a dumb question, but i want to hook up a neon light to a switch through my cigarette lighter or whatever way is easiest......could someone give me a simple diy
Midnight Heretic is offline   Reply With Quote Quick reply to this message
Old July 10th, 2003, 12:37 AM   #4
midnight accord and GQ88 ill make you a DIY by tomorrow.....itll be a new post in the interior section called neon DIY.....
cdurk5 is offline   Reply With Quote Quick reply to this message
Old July 10th, 2003, 09:09 AM   #5
Old Member
Du3ce's Avatar
good i was thinking about installing neon lights under the dash
Old July 15th, 2003, 08:00 PM   #6
hmmmm... would that work? b/c then as soon as u close the doors the lights would go off and then u wouldn't have them on while driving or anything
swtaccord is offline   Reply With Quote Quick reply to this message
Old July 27th, 2003, 03:51 AM   #7
if u want n e sort of light to go on when u open the door, u need to wire it to the middle dome light. DO NOT WIRE IT TO THE LIGHT ON YOUR DOOR THAT GOES ON WHEN U OPEN IT!! i did that when i installed my indiglo accord door sills and they only lit up when the door was closed as oppsed to it being lit up when i had the door open. i fixed the problem by wiring to the domelight instead of the door light... i dont know y, but u have to do it like that or it wont work .
djku is offline   Reply With Quote Quick reply to this message
Old July 27th, 2003, 03:54 AM   #8
___
borinka99's Avatar
did you ever post this up?
-Boris | Senior Moderator | So Cali Chapter Mod | Random Chatter Mod |
You can never master the game until you realize that it can never be mastered!
How to post pics:
borinka99 is offline   Reply With Quote Quick reply to this message
Old July 27th, 2003, 09:36 AM   #9
Old Member
Du3ce's Avatar
i know man i been waiting for that diy
