Those with 18's - Honda Accord Forum : V6 Performance Accord Forums
Old June 15th, 2003, 04:15 PM   #1
Accord Owner
Those with 18's
To those with 18's I wanna know what you riding on and if you are having rubbing problems with your drop.
I want to get 18x7.5 with 225/40/18 and has 42 offset and have it tucked.
Gimme info please THANKS !!!
00accord is offline   Reply With Quote Quick reply to this message
Old June 15th, 2003, 04:23 PM   #2
Roll your fenders and you can tuck that no problem
Hardcore_Newbie is offline   Reply With Quote Quick reply to this message
Old June 15th, 2003, 05:37 PM   #3
No tuck needed if get a 45 offset right?
r.j-lo is offline   Reply With Quote Quick reply to this message
Old June 15th, 2003, 07:59 PM   #4
So, is 00accord's setup going to rub with a drop?
I need to know because both of the rims I'm looking into only have a +42 offset (18x7.5) available and I'll be on a 2.0" drop...
I didn't find any 18's with >+42 offset that I liked yet...
dboy619 is offline   Reply With Quote Quick reply to this message
Old June 16th, 2003, 05:00 AM   #5
yea.. i have the same problem... 18x7.5 with a +42mm offset.
EnvyJK is offline   Reply With Quote Quick reply to this message
Old June 16th, 2003, 09:46 AM   #6
So, either no one knows or no one cares... Just like at work
Old June 16th, 2003, 01:57 PM   #7
I have 18", 45 offset. I used to have 215/45/18 tire. when the car is drop to the lowest, like no figure gap, tuck in the fender, driver rear rub when turning. other 3 corners doesn't. After I raise it to 1 - 1.5 inch gap, no rubbing.
but now, with 225/45/18, the car rubs if I do some "extremely" fast cornering. only happen 2 times in 6 months. I think the width of tire is part of it.
Accord123 is offline   Reply With Quote Quick reply to this message
Old June 16th, 2003, 02:46 PM   #8
if its +42 offset with 2 inch drop you will be rubbing. u will need to get your fenders rolled
Infamous425 is offline   Reply With Quote Quick reply to this message
Old June 16th, 2003, 05:39 PM   #9
so what's the perfect tire size for 18 x 7.5 with a at least 1.5 drop?
DaVEaZNPiMP is offline   Reply With Quote Quick reply to this message
Old June 18th, 2003, 01:34 AM   #10
225/40/18
Old June 25th, 2003, 02:03 PM   #11
I have an 01 accord v6 with about a 2.25 inch drop with
18x7.5 with an 43mm offset with 225-40 nankang
i rub like crazy in the back(with negative camber).
with only me in the car
i would go with a smaller tire for sure.
eckodlux is offline   Reply With Quote Quick reply to this message
Old June 25th, 2003, 02:25 PM   #12
I have 18" RH Evo C2 w/225/40/18 (+42offset) and Neuspeed Race Springs (2.25F/1.75R drop) and no rubbing problems at all... And, I packed my ride when a bunch of us went for drinks yesterday... Still no rubbing.
I was worried about it at first but the shop I bought the rims from had a 03AV6coupe also dropped on 18" C5's w/ plenty of clearance so I went ahead and bought my RH's too...
Old June 27th, 2003, 11:37 PM   #13
03 can fit bigger rims...
y0aznmasta is offline   Reply With Quote Quick reply to this message
Old June 28th, 2003, 10:38 AM   #14
Yup, I think 19's look a little nicer but I can't drive on rubberbands to work because of the crappy roads at the waterfront...
Otherwise, I would be sporting 19's too...
Old June 28th, 2003, 03:19 PM   #15
i got motegi mr7's in 18x7.5 with 45 offset, they are wrapped in 225/40/18 with a pro kit--1.5 drop, somtimes when i take turns sideways or at an angle it will rub a tiny bit...but my fenders are not rolled....once i get them rolled im sure it will be nothing.....and i wish i could have gotten 19's, but roads are ****ty and they are alot more expensive than 18's...at least the ones i wanted
Midnight Heretic is offline   Reply With Quote Quick reply to this message
