Pics of Infinity Basslink Installed in Trunk - Honda Accord Forum : V6 Performance Accord Forums
Old June 16th, 2003, 01:40 PM   #1
PitchBlk, aka BigLou 7
Loulax07's Avatar
Keep in mind that I am not done yet, especially with cable management. All I got left is finishing my kickpanels in the front.
Basslink makes some nice tight bass! Just what I needed. I highly recommend it!
Old June 16th, 2003, 01:42 PM   #2
Loulax07's Avatar
#2
Old June 16th, 2003, 01:44 PM   #3
Loulax07's Avatar
It's a self-powered 200W 10" subwoofer. I also have a controller up in the front so I can adjust the gain.
Old June 16th, 2003, 01:50 PM   #4
WOW
That looks great; nice and clean. I want to get one, but i do not know about the istall process. Can you help ME?? Is it Hard??
accordcomptech is offline   Reply With Quote Quick reply to this message
Old June 16th, 2003, 01:52 PM   #5
< DeSi BoY NocturnaL >
iLLeGaLaKKoRD's Avatar
hows da low frequencies?
Najeeb
Old June 16th, 2003, 01:58 PM   #6
Loulax07's Avatar
accordcomptech- very easy install. u need pwr from the battery, need to ground it somewhere, need the remote wire from your headunit, and RCA's from your HU OR you can splice into your rear speakers, as it has a speaker-line converter built in..
Illegal- sounds nice, maybe goes down to 25-30.
This is just for some bass reeinforcement not for boom. i have had boom b4 and i'm done wit that.......
Old June 16th, 2003, 02:02 PM   #7
Loulax07's Avatar
best thing is how little space it takes up i need room in my trunk
i'd say its the best alternative to having a box and a amp
Old June 16th, 2003, 02:07 PM   #8
Damn!
Damn dude, that is sweeeet!!!
BigVic is offline   Reply With Quote Quick reply to this message
Old June 16th, 2003, 02:18 PM   #9
Loulax07's Avatar
this is the most efficient bang for your buck i think. its smaller than a bazooka tube and much better, houses a 10" sub, looks real kool and i got it in one day from Ebay! and if u dont got RCA's from your HU, u can splice into your speakers. so all u'd need is power from the battery and thats it (at the least). it will even turn on automatically, with a switch u set, when u use the speakers as inputs
Old June 16th, 2003, 02:40 PM   #10
nice...
great work lou.
as usual
LaccordK is offline   Reply With Quote Quick reply to this message
Old June 16th, 2003, 02:49 PM   #11
Loulax07's Avatar
any questions, lemme know
Old June 16th, 2003, 02:51 PM   #12
Loulax07
Loulax07 What do you mean by rca to head union. Is this the back of the radio? Are the cables i need provided with the box? Thanks for you help.
Old June 16th, 2003, 02:56 PM   #13
Loulax07's Avatar
if u have an aftermarket headunit, they usually have pre-amp outputs in the forms of RCA's . I have front, rear & sub outs. i hooked the sub outs to my sub....
if u have the stock headunit, u can splice into the rear speakers 2 send signal 2 the sub. but they wont be tru-sub ins
Old June 16th, 2003, 03:26 PM   #14
What do you mean when you say wont be true sub ins???
Old June 16th, 2003, 09:37 PM   #15
so that's what a trunk looks like, I haven't seen one big enough to even put a bag a groceries in so long it's not even funny. Looks damn good though. Are you happy with it?
Old June 17th, 2003, 02:18 AM   #16
The basslink is no joke They're little beauties that do their job well... it's not for the SPL heads.. just enough low extension with SQ that would make any guy with a stock system very very very happy. Nice simple and clean install!
Did you try various positions and locations in the trunk and settled there as your prime location for the best bass? Or you just chose that for looks
Old June 17th, 2003, 05:27 AM   #17
Loulax07's Avatar
well, mostly b/c its where they say to put it and i've seen other mounted there. also, for more room! so it all worked out great
Old June 18th, 2003, 02:27 AM   #18
very nice setup.
for the V+ power lead...did you run one from the battery to the trunk or did you just tap into a V+ using the existing wires near the lightbulbs/tail-lamps?
SiR001 is offline   Reply With Quote Quick reply to this message
Old June 18th, 2003, 02:41 AM   #19
___
borinka99's Avatar
how much did you pay for it?
borinka99 is offline   Reply With Quote Quick reply to this message
Old June 18th, 2003, 02:43 AM   #20
i woulnt use that can of fix a flat lol i know i always change the subject
Old June 18th, 2003, 11:29 AM   #21
Loulax07's Avatar
haha, yeah, i got the fixaflat in there just in case.. i got my spare tho!
um, it cost me $200 for the basslink.
i ran a 4gauge stinger cable for the power directly from the battery for my PPI amp, focal components, and split it using a distrib block for the Basslink.
i would NOT recommend tapping the power off from a bulb. just run it back, no bigee. u can run 8awg if u just run the basslink
Old June 18th, 2003, 04:59 PM   #22
were did you get it for $200.00 bucks?
Old June 18th, 2003, 06:03 PM   #23
Loulax07's Avatar
ebay
link to the auction i won> http://cgi.ebay.com/ws/eBayISAPI.dll...ory=32822&rd=1
Old May 3rd, 2004, 01:12 PM   #24
Hey Loulax, just wondering if the Basslink screws down into the trunk floor securely.
Did you just use self tapping screws and screw it down? Is it secure? Or did you have to place wood underneath the trunk floor?
Old May 3rd, 2004, 03:32 PM   #25
Loulax07's Avatar
i screwed up from below the mat into the Basslink and used nuts/screws
Old May 5th, 2004, 05:35 PM   #26
Sorry, another question. Where did you ground the basslink?
Old May 6th, 2004, 11:45 AM   #27
Loulax07's Avatar
grounded it to a bolt in the trunk
looks like a pre-existing ground behind the rear seats. i also grounded my amp there too
Old May 12th, 2004, 07:48 PM   #28
DriVeN_AccorD's Avatar
Hey lou I was just curious about the four rca slots theres "front" and "rear" which one do I use. Am I suppose to use both front and rear?. something like this
RCA:basslink
Front Rear
L R LR
Y Y
l l
l l
l l
head unit
sub rca jack
DriVeN_AccorD is offline   Reply With Quote Quick reply to this message
Old May 12th, 2004, 08:44 PM   #29
Loulax07's Avatar
u can use either, i used the rear inputs
it doesnt matter b/c the basslink's crossover will filter out the higher freq's, thus a low-pass
Old May 13th, 2004, 12:31 AM   #30
What if I was to connect both front and rear at the same time will it have a different effect. Like would there be more bass? BTW isnt there two subs. Im looking at the basslink and I see it has like two speakers. Thats why Im thinking about connecting the rca to the front and rear. Correct me if im wrong.
thanks
