Stereo Issues - Honda Accord Forum : V6 Performance Accord Forums
Old June 20th, 2003, 03:11 AM   #1
Stereo Issues
I own a 1999 Honda Accord V6 Coupe. Now the issue I seem to be having is with the stock CD player (single). What is the problem with CD-Rs??? I mean the CD player seeks continuously for some CDs while others it works right off the bat.
My questions are as follows:
1) Is this normal?
2) Anyone find any solution for this?
Thanks
Allan
ajaslow is offline   Reply With Quote Quick reply to this message
Old June 20th, 2003, 03:39 AM   #2
Senior Member
LaoSiFu's Avatar
It is very normal. My solution is get a new head unit. I really couldn't stand my cds not reading.
In regards to Tein products, PM honda_girrrl.
Old June 20th, 2003, 04:09 AM   #3
J30A1 => J30A5 => K24Z3
TH23's Avatar
Hmm, I've never had any trouble playing CD-Rs in my headunit. Maybe Honda upgraded the '01-'02 HU to play CD-Rs? CD-RWs on the other hand will not play at all but I can accept that.
Old June 20th, 2003, 05:18 AM   #4
Your V12, My V-twin.
JonHsiung's Avatar
my 2000 coupe's stock CD player wouldn't play most burned CD-R's, but my 2000 sedan's stock CD player would play all the CD-R's i made.
I noticed that besides some minor overall differences if you take it apart, the way you can tell visibly is that the coupe's unit had "T-01" for the track numbers and the sedan's had "01" for its track numbers without the T.
it should just be regular. sorry it doesn't work. i just went ahead and swapped the head units for a couple of months, but it still didn't give out any great output for the amp+subs; now i bought my pioneer which can play rw's, mp3's, etc.
2000 AV6 Coupe
- J O N -
Old June 20th, 2003, 05:43 AM   #5
Yup Honda got the radio's for 01 and 02 to play CD-R's. I switched my 99 HU out for a 01-02 because of this. I also wanted the 6 disc in dash CD changer and tape player (for MP3 player input).
It looks really good in my car :
Old June 20th, 2003, 10:17 AM   #6
Old Member
Du3ce's Avatar
i have an 02 and it works fine i guess theres some ticks in the older versions
Old June 20th, 2003, 10:38 AM   #7
Senior Member
LaoSiFu's Avatar
didn't you told me that you took your dad's accord head unit
Old June 20th, 2003, 12:53 PM   #8
i have a 99 and my stock cdplayer plays every cd-r i have maybe your problem is the way your making the cds.
FAST99CCORD is offline   Reply With Quote Quick reply to this message
Old June 20th, 2003, 01:48 PM   #9
JonHsiung's Avatar
yes hehehehe
not like he plays cd-r's anyway.
2000 AV6 Coupe
- J O N -
Old June 20th, 2003, 02:26 PM   #10
i noticed my 00 coupe will play CDRs that are copied from a real CD, BUT when i try and play CDRs that are DLed MP3s then convert them i have that same reading problem. It will read, it just take 10 minutes!!! I made it all the way to work one day w/out the song even startin
Old June 20th, 2003, 03:24 PM   #11
JonHsiung's Avatar
yup. that's the problem i had with mine.
2000 AV6 Coupe
- J O N -
Old June 20th, 2003, 04:23 PM   #12
Phi Kappa Sigma "Skulls"
svp50's Avatar
Send a message via AIM to svp50
already posted about this...check it out here
http://www.v6performance.net/forums/...886&forumid=20
the conlusion was that memorex CD-R music will work under to conditions...they are burnt under 8x and u gotta find ones that are the old school CD-R Musics with the Shattered glass on the CD
Basicly its easyier to just get a aftermarket player or swap it out
svp50 is offline   Reply With Quote Quick reply to this message
Old June 21st, 2003, 01:26 AM   #13
my 00 sedan and 01 coupe played all CD-R was some of it caused by the type of progam use to record it
Old June 21st, 2003, 07:03 AM   #14
TH23's Avatar
Nice. I like my '01-'02 HU. Having a 6CD changer and cassette player in one unit kicks ass. The older ones were kind of lame because they were double-DIN but they were single cd only
I like your wood trim kit, it's much better than mine. I ordered the part around the HVAC controls after I bought my car and I was not thrilled with it. It has sharp edges around the radio whereas yours goes in smoothly around the radio and vents. They must've cheapened the design in recent years
Old June 21st, 2003, 08:34 AM   #15
Old Member
Du3ce's Avatar
you guys should see my 300 burnt cd collection
Old June 21st, 2003, 09:19 AM   #16
Senior Member
VTEC_V6's Avatar
Send a message via AIM to VTEC_V6 Send a message via Yahoo to VTEC_V6
My 00 sedan wouldn't play CD's all the time either, then I got one from an 01 Accord. Some it would play, other it wouldn't. Like someone said earlier. YOu need to use the Memorex Disks that are for music, and I burned mine at 24x and haven't had any problems with play back.
VTEC_V6 is offline   Reply With Quote Quick reply to this message
Old June 21st, 2003, 06:03 PM   #17
They changed the dash panel itself on the 01-02. The HVAC controls are different and so is the clock. Well to make you feel better that panel was a pain in the a$$ to get it on there. But well worth it .
Old June 21st, 2003, 09:04 PM   #18
i sugguest getting an aftermarket headunit with mp3
Old July 4th, 2003, 11:29 AM   #19
Done and Done.
Pioneer Premier DEH-P850MP purchased and custom installed. Will post pics and detailed instructions on making the steering wheel control look stock.
AJ
