jbl 600.1 - Honda Accord Forum : V6 Performance Accord Forums
Old June 22nd, 2003, 10:08 PM   #1
SHARINGAN!
Sentinel's Avatar
Send a message via AIM to Sentinel Send a message via Yahoo to Sentinel
jbl 600.1
would jbl 600.1 be underpowering two 12 DVC Type Rs?
my friend said it would be underpowering the my subs and the subs would die fast
Sentinel is offline   Reply With Quote Quick reply to this message
Old June 22nd, 2003, 10:50 PM   #2
wire the each single voice coil of each sub parallel configuration to show the amp 2ohms (600 watts rms @ 2ohms) which will make your subs sing.
And about underpowering your subs that will kill them.. your friend has a point if you crank yourgain on your amp all the way and boost your bass insanely which will drive the amp into clipping... and perhaps damage the subs... but stick with the above configuration and you'll be happy.
Old June 25th, 2003, 10:03 PM   #3
or try the 1200.01 an turn the gain down for a much cleaner sound..
BLK coupe is offline   Reply With Quote Quick reply to this message
