wats up wit my amp and woofers? - Honda Accord Forum : V6 Performance Accord Forums
Old June 24th, 2003, 06:28 PM   #1
hmmm...
i got 2 kicker comp vrs and a kicker amp... wen my friend turned the voulme all the way up, the subs just start pumping out pure bass non stop. and i had to turn off the engine for the subs to stop this...wat's wrong?
Old June 24th, 2003, 07:17 PM   #2
Old Member
Du3ce's Avatar
isnt that what theyre suppose to do???what are you talking about???
Old June 24th, 2003, 07:32 PM   #3
AV6.com OG Member
Send a message via AIM to ll kaidoy ll
huh? nothing's wrong. that's what subs are designed to do...put out bass.
ll kaidoy ll is offline   Reply With Quote Quick reply to this message
Old June 25th, 2003, 01:16 AM   #4
Jr Member
jrvtecaccord's Avatar
Do you mean that when you turn the radio down also, they are still pumping out bass, or subs still moving back and forth like crazy? If I think thats what you mean, it sounds like you have a bad ground loop.
jrvtecaccord is offline   Reply With Quote Quick reply to this message
Old June 25th, 2003, 11:01 AM   #5
hmmm...
wen i turn the bass down and turn off the radio, i still get bass and it doesn't stop....
Old June 25th, 2003, 11:24 AM   #6
Dl20ccA is Acc0l2D backwards
Dl20ccA's Avatar
Send a message via AIM to Dl20ccA
Oh, you have a stock headunit? Well, I have this same problem, easy way to fix it, either get an aftermarket headunit, or just don't turn off the headunit, just lower the volume if you want to turn it off.
I asked about the same problem awhile back, and people told me its because the stock headunit continiously sends out signals to the subs even after the headunit is turned off. Then in response the subs don't read it correctly and go full blast. Aftermarket headunits solve this problem. Or just do it like me, turn down your volume.
About the thing where if you turn the bass down and you still get bass @ full blast, i don't understand what your talking about
Dl20ccA is offline   Reply With Quote Quick reply to this message
Old June 25th, 2003, 12:08 PM   #7
hehe i had the same problem with the stock hu...like he said above...don;t turn it off...
N.O. Accorderz is offline   Reply With Quote Quick reply to this message
Old June 25th, 2003, 03:11 PM   #8
Old Member
Du3ce's Avatar
i got the same problem when i had the oem cd player i just turned my bass control knob down or if you dont have that just dont turn ur deck off.
2007 Accord EX-L V6
Old June 25th, 2003, 03:41 PM   #9
hmmm...
thamx for the he;p guys, i thought something was wrong...
Old June 26th, 2003, 09:25 AM   #10
i never had this happen with my deck i did get a 1 loud bass hit when ever i tuned on my car or off or the radio for that matter like a loud pop but i think that was due to power going to the amp. dosnt happen anymore got me a new headunit
Old June 26th, 2003, 10:42 AM   #11
Old Member
Du3ce's Avatar
when i use to have the stock deck whenever im inside and shut the car door the woofers make this echoing sound.
Old June 26th, 2003, 02:59 PM   #12
My AV6 is all gone...
6spdcoupe's Avatar
Send a message via AIM to 6spdcoupe
Instead of not turning the HU off, you can also put a switch inline with your remote wire. This will turn off the amp when not in use. If you just turn off the HU it will avoid the noise, but your amp will still be on the entire time.
--Don
6spdcoupe is offline   Reply With Quote Quick reply to this message
