Buying SUBS - Honda Accord Forum : V6 Performance Accord Forums
Old June 25th, 2003, 09:31 AM   #1
Buying SUBS
i have a 00 accord coupe v6, and im planning on buying some nice subs for my car. i was looking at rockford fosgate, becuase i hear they are good and reliable. But i was looking online and i found power acoustiks 12'' dual voice coil which pumps out twice the power of the 12'' HE2 from RF...i am definetly clueless on car audio, but i wish to become more savvy...if someone could help me out on what would be good for my car, and wha others have tried with a coupe and succeded with i would appreciate it - peace
also, what kinda amp should i get??
phatdog618 is offline   Reply With Quote Quick reply to this message
Old June 25th, 2003, 07:09 PM   #2
one jl audio 13w7 powered by a jl audio 1000/1 amp
sirsmokalot is offline   Reply With Quote Quick reply to this message
Old June 25th, 2003, 08:00 PM   #3
Jr Member
jrvtecaccord's Avatar
That would be tons of bass, but for starters try the Jl 12w3v2 with the Jl 500/1.
jrvtecaccord is offline   Reply With Quote Quick reply to this message
Old June 25th, 2003, 08:56 PM   #4
Wow back up the train... what kind of music do you listen to an 2nd do you whant sq or just plain loud???? there is a difference a big difference....
BLK coupe is offline   Reply With Quote Quick reply to this message
Old June 26th, 2003, 10:40 AM   #5
i listen to rap and rnb....i want to be hit....thats why i was thinkin of 2 12 inch subs
but i was wondering if Rockfords are good since where i werk i can get them for cheap
Old June 26th, 2003, 10:53 AM   #6
RF are some good subs, but remember to power them correctly.. 12inc he2 are really good so i hear. try either the 700x from RF or the JBL 1200.1 ikesound.com has them cheap..
Old June 26th, 2003, 12:04 PM   #7
thats only around $2000. go to a good car audio sit eand see what people recommend for your budget range. my current sub (ID MAX) and amp (Lanzar 1200d) together cost less then 1 w7 or 1000/1 and its probably as loud as the w7 for half price or less.
w3accord is offline   Reply With Quote Quick reply to this message
Old June 26th, 2003, 12:44 PM   #8
true that...i think the w7 are wayy over priced...go with one idmax or the ed12a(gettin one soon )
N.O. Accorderz is offline   Reply With Quote Quick reply to this message
Old June 26th, 2003, 02:16 PM   #9
What kind of Dbs are you hitting?
It may be loud but i doubt it can hit the low notes the W7s handle with ease. Ive sat in alot of cars and never heard anything handle the way a W7 does.
Old June 26th, 2003, 08:34 PM   #10
get 1 12" adire brahma or 1 12" eD XXX ....... 140db off that sub and a JBL 1200.1... even tho i would recommend a diff amp... the subs handle 1600 watts rms and 4800 peak... and are set up for ultimate SPL and SQ both... check HHU and audiosiege.com lots of support for both subs...
swtaccord is offline   Reply With Quote Quick reply to this message
Old June 26th, 2003, 08:37 PM   #11
i done put the wrong name... the XXX are made my RE
Old June 26th, 2003, 11:49 PM   #12
i used to have 2 - RF 10" HE2 those hit really good. powered by the RF 500a2 amp. i think i got mine for 800$ all together. right now i have 2 - 10" s10L7 Kicker SoloBarricks. i would highly reccomend i got mine for 190 each.. retail for 300$ im sure if you look around you can find the same price. are you stuck on 12"s or would you maybe go with 10"s. 12"s may hit a little deeper but 10"s will be a lot more responsive. you can find some 10"s that will sound like 12"s though too.
Myk01Accord is offline   Reply With Quote Quick reply to this message
Old June 27th, 2003, 07:43 AM   #13
I have only had my MAX for a week now, but i'm sure it can get ever low note a w7 can get. I haven't go tit metered yet.
here is a video of my MAX
w7 is on par with the idmax, brama, elemental a, xxx, and a few more. the point is that the w7 is the only one priced double the others.
Old June 27th, 2003, 08:01 AM   #14
im not stuck on 12's, but i like a deeper hit...
can anyone recommend how i should wire my system ?
and any ideas on physics setup?..(position of amp...)
Old June 27th, 2003, 08:14 AM   #15
SHARINGAN!
Sentinel's Avatar
Send a message via AIM to Sentinel Send a message via Yahoo to Sentinel
im also getting a system im getting two 12' Type Rs and a jbl 1200.1 amp what do you guys think of this setup? also did anyone have trouble hearing the treble with just stock speakers and subs?
Sentinel is offline   Reply With Quote Quick reply to this message
Old June 27th, 2003, 08:16 AM   #16
how are you planning on getting signal to your sub? aftermarket HU?
are you looking to shake people next to you, or do you just need a little more low end?
10's in general hit harder
12's in general are capable of going lower
i say in general because a 12 with 900w will hit harder than a 10 with 300w, 10s are able to hit harder because the 'hit' is usually a higher freq, and a 10 physically has less cone to move.
adding a sub is just like buying a car, what you pay for is usually what you get, and one crappy component or one that isnt capable of performing on the level of the rest will make it not worth your while.
just my $.02
davejax904 is offline   Reply With Quote Quick reply to this message
Old June 27th, 2003, 08:42 AM   #17
hey guys i have a 12inch kick solo baric, and that ****s it hard as hell with a 1000watt MTX amp i knwo the amp is not great but the speaker hits hard as hell. At the last Hot Import Nights i was at i saw the NEW kicker speaker its and 18'kicker solo X, do any of u know how good this speaker is? these r the specs.......Also what would u need to power this thing its HUGE.
Model S18X
Size (IN., CM) 18, 45.7
Impedance (OHMS) 1 DVC, 2 DVC
Max Rec Amplifier Power (WATTS PEAK) 10000
Max Rec Amplifier Power (WATTS RMS) 5000
Sensitivity (dB 1W/1M) 89.7
Frequency Response (HZ) 18-100
Mounting Depth (IN., CM) 11-3/8, 28.9
Suhvas2001 is offline   Reply With Quote Quick reply to this message
Old June 27th, 2003, 08:48 AM   #18
actually 12s hit harder 10s hit tighter. If you listen to rock, or techno then a 10 is better because they bass hits in that type of music are usually closer together. For rap and R&B a 12 is better because the bass is emphasized in those types of music and the bass is more "boomy." And a good set of 12's can still handle playing most rock and techno pretty well. Ive had both and i love 12's soo much more.
Old June 27th, 2003, 09:38 AM   #19
Old Member
Du3ce's Avatar
i need some new subs, some that hits harder. Maybe some XTants, or kickers
Old June 27th, 2003, 11:37 PM   #20
www.rmscaraudio.com
all i gots to say.
Forrest is offline   Reply With Quote Quick reply to this message
Old June 28th, 2003, 12:51 AM   #21
Nikerey, I sit corrected on my choice of words. . . but i do agree that 12's are better
