customizing cluster - Honda Accord Forum : V6 Performance Accord Forums
Old September 7th, 2005, 03:55 AM   #1
customizing cluster
Hi,
Does anyone know if I could use replace the 98 gauges with a 02 gauges..can you just just swap the faces or you actually have to replace the whole thing?
aznstud408 is offline   Reply With Quote Quick reply to this message
Old September 7th, 2005, 12:45 PM   #2
Destroyer of Tires
Doctor_X's Avatar
If your going to swap the gauges then why not just get some reverse indiglo off eBay?
Old September 7th, 2005, 12:46 PM   #3
keepin' it OG
you can do it, its easy... just make sure you get the correct model for your car...
and things to worry about, such as if their was any previous damage, or if someone has messed around with the needle...
KIET
Old September 7th, 2005, 01:17 PM   #4
I want the mileage to be the same as wut it currently is tho....
Old September 7th, 2005, 01:22 PM   #5
i know for fact that 98-00 gauges dont work on 01-02. the water temp needle is not compatible for some reason.
Viper is offline   Reply With Quote Quick reply to this message
Old September 7th, 2005, 01:24 PM   #6
I don't want to replace the whole thing...just the plastic face and needle
Old September 7th, 2005, 01:28 PM   #7
keepin' it OG
you can remove the face.... and keep your original mileage
KIET
Old September 7th, 2005, 01:49 PM   #8
And the red needle too right?
Old September 7th, 2005, 01:55 PM   #9
keepin' it OG
when you take off the face, the needles will stay intact with the face... just leave the needles alone..
KIET
Old September 7th, 2005, 02:37 PM   #10
I hate my Ford
timdastis's Avatar
Send a message via AIM to timdastis
i just used a red sharpie marker to make my orange needles red
timdastis is offline   Reply With Quote Quick reply to this message
Old September 8th, 2005, 01:34 PM   #11
LaLaLaLa
stupidaznmunkey's Avatar
i cant believe 01-02 has a water temp gauge thats not fair. damn i still need to recalibrate my gas needle...however you do it...
Old September 17th, 2005, 04:53 AM   #12
water temp gauge? where is that location on a 2001 v6 coupe? anyone with pic of that gauge? is that the same one on the right of gauge cluster? engine temp same?
Old September 17th, 2005, 07:13 AM   #13
bryan <3's bomex
mastadulog's Avatar
water temp = engine temp
