Problems painting interior... please help - Honda Accord Forum : V6 Performance Accord Forums
Old October 9th, 2005, 11:55 PM   #1
Exclamation Problems painting interior... please help
Alright, so I decided to paint my wood grain trim black today. First piece i started off with is the driver side panel where the window controls are. I got everything out no problem. Here is where I am running into problems:
I wet-sanded down the clear coat a little bit with 1000 grit sand paper (i had paint stripper, but when i read the instructions, it said don't use on rigid plastic, so i decided against it). I then applied black Sandable Dupli-Color primer. After a few coats, and wet-sanding in between each coat, I started painting on black Dupli-Color Auto Spray.
I wasn't sure if I should wet-sand it or not, but I didn't like how it didn't have a smooth texture, so I tried wet-sanding it. The paint seemed to be coming off, so I put on a coat or two more and didn't sand it, hoping the clear coat would smooth out the look.
After all that, I put on the clear-coat and let it dry. Still not the smooth/glossy look I'm looking for. So I tried wet-sanding that too. It seems to me that it took off most of the clear-coat and even some of the paint underneath. This was 5 or so minutes ago, and I just put on another coat of black paint since it looked like the primer was showing through a bit because of the sanding.
In conclusion, what am I supposed to be doing to get a smooth glossy black look? And am I wet-sanding wrong (basically, I'm dipping the sand paper in water and then sanding like normal)? I can't quite figure out what to do so that the paint doesn't come off.
Thanks in advance for all the help
trickster is offline   Reply With Quote Quick reply to this message
Old October 10th, 2005, 12:27 AM   #2
CRV_33's Avatar
if you want that black glossy look alot of it has to do with the paint itself. Also what color primer are you using? If you using black primer, I don't think its going to turn out well.
Heck i just painted some black outlet cover for my brother since apparently Lowes, Home Depot, and Menards don't carry it in black but they do brown??
Well here is how it turned out:
In this case I just used white primer (whitish gray in color). Then I just sprayed on some Black Kyrylon paint. In the picutre it looks really glossy, so you can imagine how glossy it will be when I apply the clearcoat later.
Old October 10th, 2005, 12:31 AM   #3
CRV_33's Avatar
In your case i would just take some dish soap and apply it to your pieces that you already painted to not only clean the surface, but dish soap strips the clearcoats too Then just take some sand paper and sand it down til the surface is smooth (probably be a good idea to clean the surface again to get rid of dirt and dust from the sanding). . Next spray like 2-3 coats of light primer (white or gray primer works). After the primer has set I would spray 3-4 coats of black (make sure its not flat black) and then just let it air dry. And then I would coat on some 4-5 layers clearcoats after the paint has dried thoroughly.
Hope the directions are clear and GOODLUCK!
Old October 10th, 2005, 12:33 AM   #4
THLA 2009 Bombsquad
Dtownz Thrillah's Avatar
well there is gloss black paint too ..
Old October 10th, 2005, 12:37 AM   #5
Thanks for the help and quick replies
I'm confused as to why white primer would work better than black primer for black paint. In addition, I'm guessing I shouldn't be wet sanding?
Old October 10th, 2005, 12:42 AM   #6
Oh, and I'm thinking maybe I should have tried the Brilliant Black instead of the plain old Black. Any opinions on that?
Old October 10th, 2005, 12:46 AM   #7
it helps the black color come out...
for example... to dye black hair red, you have to bleach it first to help the red stand out.. same token
