Hey all, I have a problem with my seats.
Recently I bought power leather seats from a member on this board. The seats were out of a '01 V6 EX Coupe. I have a '98 I4 LX Coupe. Needless to say, I have cloth, manual seats.
The passenger side was easy to put in because it is still a manual-manual swap.
But the driver side is an 8-way adjustable seat, whereas I have manual. The problems I am having are as follows:
-The Alignment is Off (after powering the seat before putting it in the car, I tried to adjust it but the seat sits very far back even though I pressed it up all the way)
-Where does the wiring harness that would normally connect to the bottom of the seats actually go to? I can probably obtain one or make one if I knew where it went to.
-Would swapping the brackets/sliders from manual seat onto the power seat actually work? Would the bolts line up? This would be an easy solution instead of powering the seats as I dont care about power.
Any help would be greatly appreciated. Oh and I am located in central Jersey if anyone wants to be nice and help me out with it (I'll buy you lunch). Thanks.
