bumber from 01 to a 99!!! anybody knows if they'll fit? - Honda Accord Forum : V6 Performance Accord Forums
Old November 1st, 2005, 04:31 PM   #1
hi, peeps, do you guys know if the front bumber from a 01 coupe will fit into a 99? if so, will there be any modifications needed? help me??
blackonchrome is offline   Reply With Quote Quick reply to this message
Old November 1st, 2005, 05:21 PM   #2
may not. because the promblem is at the top front grill. you need to change the par that hold the 3 plastic pins. hope u know wat i mean, here are the pic[IMG][/IMG]
02SilverAcc2dr is offline   Reply With Quote Quick reply to this message
Old November 1st, 2005, 05:21 PM   #3
JB4 e92
clean2draccord's Avatar
No modifications, perfect fit.
Old November 1st, 2005, 05:57 PM   #4
metallikatz3's Avatar
Send a message via AIM to metallikatz3
yeah it'll fit fine
metallikatz3 is offline   Reply With Quote Quick reply to this message
Old November 1st, 2005, 06:00 PM   #5
how bout a 6th gen sedan bumper going into a coupe? mods needed?
Old November 1st, 2005, 06:13 PM   #6
POS driver
98CG__sHow's Avatar
Send a message via AIM to 98CG__sHow
you'' need a sedan hood
98CG__sHow is offline   Reply With Quote Quick reply to this message
Old November 1st, 2005, 06:31 PM   #7
v not some model, my girl
99v6sedan's Avatar
Old November 1st, 2005, 06:33 PM   #8
Old Member
Du3ce's Avatar
how many times have this topic been discussed now???
Old November 1st, 2005, 06:37 PM   #9
99v6sedan's Avatar
soooo many times.......people need to learn how to search.
Old November 2nd, 2005, 01:32 AM   #10
thanks for the tip, guys, i just got in a accident, my radiator support and front reinforcement bar is twisted and bented. gotta bring it out the shop to fix it before putting on new hood, bumber and headlights...sigh .... you could see the accident pic in my profile. Anybody familiar with CF hood from ebay? are they acceptable? I checked and it look pretty good but you know how stuffs off ebay are...
Old November 2nd, 2005, 01:35 AM   #11
Destroyer of Tires
Doctor_X's Avatar
Kind of off topic... but at the same time on topic here. I think that it would be kind of cool if someone took the sedan front bumper (98 - 00) and they got the WW kit for the front then did the rest like Mugen... or WW... or Kaminari or something. What do you guys think?
Old November 2nd, 2005, 06:31 AM   #12
99v6sedan's Avatar
i am actually in the process of repairing an accord at my work with alm ost the same damage. his whole radiator support needs to be replaced, the hood buckled like yours and the striker on the hood pulled the latch and radiator support up so high it pulled the lower support into the condensor and radiator, pics will be in my gallery today after work. sorry to hear about your baby
Old November 2nd, 2005, 11:34 AM   #13
oh i see, well yea, i need to replace what you said, can you give me a quote of how much it usually cost to fix? also the bumber for 2001 fit into 99 without any problems? same bolts and clips locations? so the only thing different from a 2001 bumber and a 99 bumber is the style?
Old November 2nd, 2005, 05:34 PM   #14
JB4 e92
From what I've heard, don't buy anything but authentic VIS or OE Tuning CF hoods.
Old November 2nd, 2005, 05:41 PM   #15
jinsoku.com
vTecaznracer's Avatar
Send a message via AIM to vTecaznracer
932479812374 times.
vTecaznracer is offline   Reply With Quote Quick reply to this message
Old November 2nd, 2005, 06:08 PM   #16
99v6sedan's Avatar
prices are different from state to state and shop to shop. you also might not need your whole radiator support replaced, maybe just your upper tie bar. the grille lines are different from 98 99 to 00-02 and also the hood, to match the grill lines. my cf hood actually is for an 00-02 and it doesnt line up with my grille, when the time comes ill just shave the corners off the hood to line it up. i think the center bumPer mounting brackets points are different. there is 3 mounting brackets, 1 under each headlight and the 1 inbetween your headlights that the grill mounts to. i have a 01 accord at work that i will compare mine with tomorrow so i can let you know for sure.....
Old November 2nd, 2005, 06:34 PM   #17
Destroyer of Tires
Doctor_X's Avatar
