Problem taking my front bumber off.. - Honda Accord Forum : V6 Performance Accord Forums
Old December 7th, 2005, 12:13 PM   #1
Exclamation Problem taking my front bumber off..
Hi, Ive tryed to take my 98 accord coupe front bumber off to install a top grill i bought...but im having trouble...can anyone help?...is there any posible way of takeing the top grill off without taking the whole bumber off?....thanks
19-BlackV6-98 is offline   Reply With Quote Quick reply to this message
Old December 7th, 2005, 12:31 PM   #2
chido's Avatar
Send a message via AIM to chido Send a message via MSN to chido Send a message via Yahoo to chido
I believe that there are 4 to 6 screws on the underside of the grill that need to be removed. I think the radiator support makes these difficult to.
chido is offline   Reply With Quote Quick reply to this message
Old December 7th, 2005, 12:35 PM   #3
THLA 2009 Bombsquad
Dtownz Thrillah's Avatar
yeah you need to take off the wholr front bumper .. shouldnt be hard at all ..
One bolt on each side of the front fenders ..
I think 5 on the front grille ..
And then 4? On the very bottom of the bumper ..
hope that helps you out .. should be easy man ..
Old December 7th, 2005, 12:39 PM   #4
No, the only and best way for you is to take the bumper off. Youll save more time and less stress on yourself by taking off the bumper rather then trying to squeeze through that space. First off, open your hood, there should be about 5 plastic pins along the radiator support, you just need to pull those out. 2nd, there should be 1 pin along the fenderlining in your wheel well, turn ur tires when taking them off, itll be easier (do that for both sides as you switch) Last, there should be some plastic pins below the front bumper, not sure how many there are on a 98. But there are 4 on a 01-02, two of them in the middle which connect the bumper to the body, and one on each side which connect to the fenderlining. Hope this helped
maying856 is offline   Reply With Quote Quick reply to this message
Old December 7th, 2005, 08:21 PM   #5
v not some model, my girl
99v6sedan's Avatar
there is also 2 phillips head screws on the underside of the bumper where it wraps around to meet the fender. slide a flathead screwdriver under the heads of the plastic clips (push rivits) securing the grille and underside of the bumper and turn it sideways to lift the center out of the push rivit. that saves them so they can be used again. careful though ive had the heads break in half before. i keep em on reserve at the shop..... just incase
99 Accord V6 Sedan
CG Squad Member #16
Official Slammed Club Member #47 Stage 4
A.S.E. Certified Autobody Technician
Old December 7th, 2005, 11:09 PM   #6
THANKS ALOT GUYS, that help a lot
Old December 7th, 2005, 11:26 PM   #7
OK...i got all the top plastic pins on top and bottom... i got the 2 Bolts by the side fenders...hmmm what else?...i don get what part of the bumper youre talk about? but ill look around the bumber...
Old December 7th, 2005, 11:41 PM   #8
It should come off.....
Old December 7th, 2005, 11:47 PM   #9
bumPer
there should be 4-6 clips on top and 6-8 on the bottom + the 2 bolts. Just Give it a little pull and it should come off
janiVI is offline   Reply With Quote Quick reply to this message
Old December 8th, 2005, 03:10 PM   #10
I hope so....damn this would be my third time trying it LOL....anyways thanks guys...ill try to postup a pic when i get the grill on if i can even get it on LOL..k thnks
