Rim size/spec question - Honda Accord Forum : V6 Performance Accord Forums
Old January 26th, 2006, 01:05 PM   #1
this is for a 6th gen coupe 4 cyl. 17x7 or 17x8... Also what offset do you guys recommend? They only offer 25+ or 35+ for the particular rim I am looking at.. I also hear that 215-45-17 is a nice tire size to go with.. or should I stick with 225-45-17.. Sorry I am not familiar with smaller size rims. Thanks for your help in advance.
SnorringTiger is offline   Reply With Quote Quick reply to this message
Old January 26th, 2006, 01:29 PM   #2
CRV_33's Avatar
well i'm not really sure about the offset but you should be able to go with 225 wide tires on a 7" rim.
Old January 26th, 2006, 02:49 PM   #3
HONDA_99's Avatar
7" wide rims -> offset range +42mm to +50mm
8" wide rims -> offset range +48mm to +50mm
Old January 26th, 2006, 03:06 PM   #4
(つ◕‿◕)つ*.★.*.★.* .★.
Red02AccordV6_2's Avatar
what about a 8'' rim with +45 offset and 235 tires? for a 6th gen coupe
Old January 26th, 2006, 03:12 PM   #5
HONDA_99's Avatar
in your case it depends on how low your car is.
Old January 27th, 2006, 06:43 PM   #6
I'm dropped on Hr Sports
Old January 27th, 2006, 10:48 PM   #7
Team ACCA
VIET01AV6's Avatar
Send a message via AIM to VIET01AV6
you can fit 225 in the rear but it will stick out in the front with 225
VIET01AV6 is offline   Reply With Quote Quick reply to this message
Old January 28th, 2006, 08:33 AM   #8
HONDA_99's Avatar
i don't know spec for all springs that on market, but if its like 1.5" drop then you should be ok.
