Recommendations on an amp to power MB Quart RSD216 - Honda Accord Forum : V6 Performance Accord Forums
Old July 11th, 2003, 12:46 PM   #1
There are not many car stereo shops where I am living right now so I need to buy a good 4-channel amp off the web (without listening to it). I would like your opinion on one before I choose.
For speakers I have MB Quart RSD216s in the front, and stock speakers in the rear. The RSD216s have the following specifications:
Impedance: 4 Ohms
Frequency Response: 38-32k
Sensitivity: 86 dB
Power Range: 60-130 watts
Crossover Freq: 2500Hz Hz
Crossover Slope: 12 dB/octave
Please recommend a strong, loud, musical, "clean", but economical 4-channel amplifier to power these speakers.
nitinj is offline   Reply With Quote Quick reply to this message
Old July 11th, 2003, 01:02 PM   #2
what's your price range?
Are you afraid of using eBay as a possible source?...or do you want an authorized online dealer(cbrstereo, carmedia1, sounddomain, mainstreetaudio, etc)?
Old July 11th, 2003, 01:07 PM   #3
I don't really have a price range. If it is really worth the money, I will save up and buy the right choice. I just want some recommendations. It can't be too expensive, it will only be running RSD216s, not anything like the utopias.
Ebay is cool. I just need the model number for the exact amplifier I am buying. I don't want a crap one.
Old July 11th, 2003, 01:47 PM   #4
What do you think about this amp:
Phoenix Gold Octane R 8.0:4
costs $222.95
4 Channel amplifier
12dB HP/LP variable crossovers
full range aux output
Dimensions: 15.75L x 10.875W x 2.25H
125W x 4 (4 ohm) • 400w x 2 (4 ohm)
Old July 11th, 2003, 02:10 PM   #5
I am also considering this amp:
JL audio 300.4
cost $350
Rated Power (stereo): 75 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (bridged): 150 W RMS x 2 @ 3 ohm-8 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm
S/N Ratio*: >108.5 dB below rated power
Frequency Response: 5 Hz-30 KHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch./50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
I got a chance to hear this one on some MB Quart PCE216s. The amp sounds a'ight, nothing special.
Old July 11th, 2003, 06:15 PM   #6
Memphis 16-MC3004
cost $340
RMS Power 4 ohm (Watts) 75 x 4
RMS Power 2 ohm (Watts) 115 x 4
THD 4 ohm - 0.03%
Frequency Response +/- 1 dB - 10Hz-50Khz
Dimensions (in.) 6.5 x 2 x 16.4
Old July 11th, 2003, 06:20 PM   #7
Also, this guy:
Precision Power PCX-480
cost $335.00
4 ohm: 80
2 ohm: 160
Bridged: 320
Damping: >500
S/N Ratio: >110dB
THD: 02%
Power Input: 4 Guage
Freq. Resp.: 4.5-100k
I/P Sens.: .15-12V
X/O Slope: 12dB
X/O Freq.: 30Hz-4KHz
X/O Type: 2 way
Input Type: 12 vDC
Cooling Fan: Yes
QBass: QBass™
Old July 11th, 2003, 06:28 PM   #8
Get the JL Amp. That's the amp I'm using and it sounds amazing with the comps. That's actually the exact same setup as mine. (MB Quart 6.5s and JL 300.4 amp)
Here's a pic of the amp installed...the install is nothin fancy, but it looks good enough.
loxllxol is offline   Reply With Quote Quick reply to this message
Old July 11th, 2003, 07:00 PM   #9
Smile 2 AMP
YOU DON'T NEED THAT MUCH POWER TO RUN YOUR HIGH..
YOU WILL NEED THAT POWER TO RUN YOU AMP ON YOUR LOW IN THE FUTURE. CHECK YOUR ALT ON YOU DOOR YOU TO SEE THE AMP RATING YOU NEED THAT POWER.
GOOD LUCK..
shogos is offline   Reply With Quote Quick reply to this message
Old July 11th, 2003, 07:08 PM   #10
Re: 2 AMP
GOOD LUCK..
I don't have both amps runnin to my comps. The right amp is for my interior speakers and the left amp is for my 2 JL's in the trunk.
Old July 11th, 2003, 08:08 PM   #11
I AM SORRY BUT I DID NOT SEE THE PIC OF YOUR SETUP.
ANY WAY ONE AMP IS FOR YOUR HIGH AND MID.
THE OTHER ONE IS FOR YOUR LOW..12"-15"(HIGH CURRENT AMP)
THAT HOW YOU GET CLEAN SOUND.. THE HIGH YOU DON'T NEED EXPENSIVE AMP BUT A GOOD ONE ALPINE..
Old July 11th, 2003, 10:55 PM   #12
My AV6 is all gone...
6spdcoupe's Avatar
Send a message via AIM to 6spdcoupe
Out of the ones your posted I would pick the PPI. Otherwise...Eclipse,Memphis,Diamond Audio,PG,Soundstream,etc..But all the ones you mentioned shouldnt be bought off of ebay or any onlines stores...there is no authorized dealers for them.Therefore no warranty, and possibly not real equiptment.
--Don
6spdcoupe is offline   Reply With Quote Quick reply to this message
Old July 12th, 2003, 10:15 AM   #13
Here is another one:
Eclipse PA5422
cost $360
200W × 4 Channel Max. Power Output at 2
120W × 4 Channel 0.1% THD at 2 Stereo, 20–20,[email protected]
(RMS Continuous Power)
85W × 4 Channel 0.1% THD at 4 Stereo, 20–20,[email protected]
ChannelFlex Crossover
High-Pass Crossover (12dB/octave, 120Hz)
Adjustable Low-Pass Crossover (12dB/octave, 50–200Hz)
Adjustable Pre-Out High-Pass Crossover (12dB/octave, 50–200Hz)
Subsonic Filter (0–50Hz)
Free-Flow Signal Circuit
Double-Sided PCB
High-Current, High-Speed Output Devices
High-Efficiency, High-Energy MOSFET Power Supply
Audiophile Grade Component Selection
Intelligent 7-Way Discrete Protection Circuitry
Music Reproduction with Low Distortion & Ultra-Low Negative Feedback
Efficient Cooling with Low-Profile Heatsink
Multi-Mode Configuration
Stereo/Mono Switch
2 Stable Design
Old July 12th, 2003, 10:49 AM   #14
Here is another amp:
Diamond Audio D5 600.4
cost $429.00
RMS Output Power 75W x 4 @ 4 Ohm Stereo
150W x 4 @ 2 Ohm Stereo
300W x 2 Bridged @ 4 Ohms
Freq Response: 10Hz-50KHz
Signal-to-Noise Ratio: 102dB
THD: 0.03%
Channel Separation: 80dB
