Rms? - Honda Accord Forum : V6 Performance Accord Forums
Old July 11th, 2003, 05:56 PM   #1
Rms?
Ok, I have a question about RMS. I was always under the impression that RMS was how many watts you could put to a speaker and it not blow up. A guy at a audio shop just told me that you could run anywhere between RMS and Peak and be ok. And RMS was the lowest amount you needed to put to the speaker. Can someone clear this up with me?
BTW we were talking about Alpine Type R 5 1/4 componets>
ICEYACCORD is offline   Reply With Quote Quick reply to this message
Old July 11th, 2003, 06:02 PM   #2
You want to keep the power as close to the RMS rating of the speaker as possible. This will ENSURE you do not blow the speakers. Technically, you can run above the RMS rating, but it is better for the speaker life not to. Going over the RMS rating will put the speaker that much closer to the PEAK power handeling rating which it can endure, but only for a VERy shrt period of time.
Old July 11th, 2003, 07:19 PM   #3
That's what I thought, but if I put 50 RMS to where it calls for 40 RMS it should be ok?
Old July 11th, 2003, 08:33 PM   #4
What's the PEAK for those speakers?
Old July 11th, 2003, 10:32 PM   #5
160W peak is what the box says.
And the 6x9's are 50watts with 120W peak.
Old July 12th, 2003, 12:43 AM   #6
NuFFsTyLeZ's Avatar
Send a message via AIM to NuFFsTyLeZ
Crutchfield.com has a lot of good info you can use. Tells a lot about peak and rms. I usually use my speakers up to the rms. Anything over and the speakers will start so sound bad. Like it's straining to play.
NuFFsTyLeZ is offline   Reply With Quote Quick reply to this message
Old July 12th, 2003, 12:54 AM   #7
With that said, then you could run UPTO about 60 watts or so.
With that kind of peak rating you will be FINE.
If you start getting to about 75 watts or so, then you are running TOO much POWER.
Old July 12th, 2003, 01:01 AM   #8
ok, thanks guys. I think I'm going to print out the glossary from Crutchfield and take it to that guy tomorrow.
