AS IS The AIR PRESSURE, RINES 18 X 8,5? - Honda Accord Forum : V6 Performance Accord Forums
Old July 12th, 2003, 07:04 PM   #1
HEY, FRIENDS, I NEED ITS COMMENTARIES, IN RELATION To the AIR PRESSURE, THAT I MUST PUT IN MY RIMS, for MY ACCORD. I HAVE RINES To HIM 18 X 8.5 . I WAIT FOR YOURS COMMENTARIES.
josered is offline   Reply With Quote Quick reply to this message
Old July 12th, 2003, 07:09 PM   #2
V Go SoCal Drivers V
bustedryde's Avatar
what the hell are you trying to ask?
Old July 12th, 2003, 07:19 PM   #3
WHICHEVER AIR POUNDS I PUT To HIM To The TIRES.
Old July 12th, 2003, 07:24 PM   #4
bustedryde's Avatar
check the wall of your tires, the max PSI should be there. Mine is 45, and I have the same sized rims you have(225/40/18)
Old July 12th, 2003, 07:31 PM   #5
OK. ALREADY the DOUBLE CHECK, SAYS 45 PSI, but IT IS the MAXIMUM PRESSURE, I ASK, IF I TAKE THEM PSI to 45, I DO NOT HAVE SOME TYPE OF WEARING DOWN
Old July 12th, 2003, 07:40 PM   #6
bustedryde's Avatar
DO NOT take it to the max...the air will expand when you drive
Old July 12th, 2003, 07:44 PM   #7
OK.BUSTERDRYDE, THANKS FOR ITS COMMENTARIES And THEIR PATIENCE.
Old July 13th, 2003, 01:22 AM   #8
Run stock recommended pressures, 30 all around. Air pressure depends on the car's weight, not the rim/tire.
Sam
Sam Lin is offline   Reply With Quote Quick reply to this message
Old July 13th, 2003, 01:23 AM   #9
Clarification: That's 30psi in all 4 wheels, measured COLD.
Sam
Old July 13th, 2003, 01:23 AM   #10
im running 33 in each wheel....225.40.18s
