so disappointed :/ - Honda Accord Forum : V6 Performance Accord Forums
Old July 13th, 2003, 06:00 PM   #1
SHARINGAN!
Sentinel's Avatar
Send a message via AIM to Sentinel Send a message via Yahoo to Sentinel
so disappointed :/
i got my subs in two 12' type Rs and JBL 1200.1 amp in my sedan. the bass is REALLY REALLY loose, it doesen't hit hard like my friends mtx 8000s with a jbl 600.1. any way i can make em hit as hard as his? i was told mines SHOULD hit nicer
Sentinel is offline   Reply With Quote Quick reply to this message
Old July 13th, 2003, 06:09 PM   #2
Old Member
Du3ce's Avatar
play with the gains on ur amp settings
Old July 13th, 2003, 09:29 PM   #3
SHARINGAN!
Sentinel's Avatar
is it because im using the stock head unit?
Old July 13th, 2003, 09:45 PM   #4
Old Member
Du3ce's Avatar
no i use to have a system hooked up to my stock hu and it pounds hard
Old July 13th, 2003, 10:01 PM   #5
sonnieeeeboi's Avatar
what kind of box are you using? is it sealed? or a bandpass?
Old July 13th, 2003, 10:02 PM   #6
Old Member
Du3ce's Avatar
yeah that could be the reason
Old July 13th, 2003, 10:06 PM   #7
SHARINGAN!
Sentinel's Avatar
i have no idea what that means? its just the a box that has two big holes for the subs and metal things in the back for the wires =T
Old July 13th, 2003, 10:19 PM   #8
Old Member
Du3ce's Avatar
lmao i guess ur a newbie at this i guess from ur explanation its probably a sealed box which means the box is sealed in, a bandpass is both seal and ported. Look on ur woofer specs to see which box it would fit in
2007 Accord EX-L V6
Old July 13th, 2003, 10:25 PM   #9
AV6.com OG Member
Send a message via AIM to ll kaidoy ll
the box may be too big for the subs. Type R's don't need a large box to work effectively.
ll kaidoy ll is offline   Reply With Quote Quick reply to this message
Old July 14th, 2003, 07:20 AM   #10
Yep, it sounds to be a box problem. "A box with 2 big holes" means it's a vented box, the interior volume in addition to having ports not being tuned to whatever sub you have will give you ****** results. Now go read the specs on a type R and you'll see you only need about a 0.5 - 0.85 cube feet sealed(per sub). Go find a pre-fab sealed box online...
Lastly, if you continue to play those subs with extreme exursion and you do not use a subsonic filter, you will eventually blow those subs.. just from mechanical constraints.
Old July 14th, 2003, 01:11 PM   #11
SHARINGAN!
Sentinel's Avatar
where do i get a subsonic filter or whatever? :/
Old July 14th, 2003, 01:26 PM   #12
I dont know where one could get a specific hz notch filter... mostly it's built into either the HU, EQ, or amp. Best bet for you to do is change your dual sub enclosure and pickup a sealed dual sub enclosure with the correct internal volume. You wont need to worry about sub-sonic filters with sealed boxes, and you will have the tight bass you've been lacking.
Old July 15th, 2003, 01:45 AM   #13
since you have a sealed enclosure box , is it empty inside? try messin wit ur amp functions, also try filling in the box wit a sh** load of thick cotton..., but make sure the wires dont touch the fibers..i stuffed my box and then covered it with a piece of clotch and then put my subs in....it worked pretty good afterwords..
Old July 15th, 2003, 04:24 PM   #14
Type Rs suck in anything other than sealed. Make sure its the right air space. And 12s arnt supposed to hit tight....12s are for low boomy bass, if you want tight get 10s. or even 8s
Old July 15th, 2003, 05:40 PM   #15
My AV6 is all gone...
6spdcoupe's Avatar
Send a message via AIM to 6spdcoupe
Ya lost me here L_fty, how does a "box with two big holes" make it a vented? Wouldnt it be a "box with 2 big holes, and slots/more holes"?
Otherwise what everyone else is saying is pretty much correct, you have the wrong size enclosure, get a box to fit the correct specs for the subs.
--Don
'03 6MT Coupe/Navi with Lots of mods...Sold
'05 G35 Premium/Aero/Sport...
6spdcoupe is offline   Reply With Quote Quick reply to this message
Old July 15th, 2003, 05:51 PM   #16
I don't know about all of you; but I've found any box you buy at a retail store is NORMALLY too big for the speakers. When I bought some at Circuit City it came w/ a 2.5 cu foot box that didn't even separate the two 10"s; it was just one big open area. I since built my own 1.5 cu foot box w/ a seperator dividing the two subs. So now if I push one in; the other one doesn't move, w/ the retail one I bought if I pushed one in the other would stick out....
just my experience...
Building is a PITA; but; unless ya can find a good one to buy might want to :-/
k3yz is offline   Reply With Quote Quick reply to this message
Old July 15th, 2003, 09:22 PM   #17
--Don
Well.. I thought he meant that the holes were perhaps port holes.. in either a ported or bandpass box...in which case both boxes are technically "vented"....
damn you for being so technical
Old July 15th, 2003, 10:21 PM   #18
6spdcoupe's Avatar
