OEM Black housing condensation - Honda Accord Forum : V6 Performance Accord Forums
Old March 12th, 2006, 10:02 PM   #1
MuGENStyleV6TEC's Avatar
Send a message via AIM to MuGENStyleV6TEC
This subject has probably been talked about to death, but i have condensation after doing DIY Blackhousing. one side is fine, and ive tried resealing the other side 3 times and its getting to be annoying to have to slowly heatgun it to get it off and reapply seal. This time around i was thinking about buying 10 cases of seaweed for my friend, and keeping the HUGE Dessicant Salt packets, and putting them into my headlight to absorb water in the air. But anyone got any better ideas before i salt my headlights?
MuGENStyleV6TEC is offline   Reply With Quote Quick reply to this message
Old March 12th, 2006, 10:45 PM   #2
keepin' it OG
take off all the junk off the headlight and seal it again... i blackhoused a pair of headlights that was really bad in shape (no names ) and i he hasnt come back to me with problems yet. nor the other two i did that same day.
KIET
Old March 13th, 2006, 09:13 PM   #3
I've tried that 2 times, the problem still keeps coming up
Old March 14th, 2006, 10:36 AM   #4
keepin' it OG
do it again and lube it everywhere withthe silicone. and remember to take everything off this time, old oem silicone and the clear silicone... they are useless now.
Old March 14th, 2006, 10:46 PM   #5
I'll give it a shot, and ima throw in the salts for good measure
Old March 14th, 2006, 11:36 PM   #6
from my experience, dessicant gel packs, silicon packs of any size of type wont really make a difference in keeping the condensation out. Silicon seals around the housing will get messy if you keep having to reapply it. Like Kiet said, clean off all the old seals and put your headlights back together again. This time when the housing and the lense are pressed together get a clear silicon type II tube and cut the tip to open just a small hole. Now stick that tip into the crevices of the headlights and squeeze hard. Make sure the silicon completely fills up the open spaces with no gaps left. Continue around the rest of the headlight like that. Let it dry overnight and then reinstall it. If you get impatient you'll mess up the seal before it properly dries.
blkb6couper is offline   Reply With Quote Quick reply to this message
