Your sub setup - Honda Accord Forum : V6 Performance Accord Forums
Old July 14th, 2003, 08:49 PM   #1
Your sub setup
Just wondering what everyone else is using in their car (# of subs & size (10'', 12''...))
Wolf is offline   Reply With Quote Quick reply to this message
Old July 14th, 2003, 08:57 PM   #2
2 10's
BLK coupe is offline   Reply With Quote Quick reply to this message
Old July 14th, 2003, 10:30 PM   #3
Phi Kappa Sigma "Skulls"
svp50's Avatar
Send a message via AIM to svp50
3 10's bandpass box
svp50 is offline   Reply With Quote Quick reply to this message
Old July 14th, 2003, 10:38 PM   #4
1 12
davejax904 is offline   Reply With Quote Quick reply to this message
Old July 14th, 2003, 10:41 PM   #5
Old Member
Du3ce's Avatar
2 12' sealed box
Old July 14th, 2003, 10:41 PM   #6
AV6.com OG Member
Send a message via AIM to ll kaidoy ll
2 12s in a sealed box (for now)
ll kaidoy ll is offline   Reply With Quote Quick reply to this message
Old July 14th, 2003, 10:41 PM   #7
2 12" L7s in a HUGE slot ported box.
Old July 14th, 2003, 10:52 PM   #8
what is the difference btwn: 3 10's and 2 12's, ported and sealed box, and subs facing the seats and rear bumper
Old July 14th, 2003, 11:08 PM   #9
3 10s should be much tighter than 2 12s, there's less resistance to each piston moving, so it can make much tighter movements, although they should be about the same loudness with the 3 10s being slightly louder depending on the drivers themselves and the whole setup, apples to apples, 2 12"S have about 226 square inches of surface area, 3 10s have 235 square inches. A good sized sealed box has the best dynamic range and cleanest sounding, but isn't for high SPL. Ported and bandpass ported boxes are meant to maximize SPL, most of the time at the sacrifice of sound quality. Although if the tuner really knows his stuff a ported can be pulled off with a relatively flat rolloff(clean smooth sound). Facing you you hear just the subs themselves, facing them towards the back you use your trunk as a psuedo bandpass enclosure, with the trunk acting as the secondary chamber. It makes it louder by resonating through the trunk.
Old July 14th, 2003, 11:11 PM   #10
2 12's in a sealed box
aznpnoy562 is offline   Reply With Quote Quick reply to this message
Old July 15th, 2003, 02:21 AM   #11
azn010's Avatar
Send a message via ICQ to azn010 Send a message via AIM to azn010
1 10" in a bandpass
azn010 is offline   Reply With Quote Quick reply to this message
Old July 15th, 2003, 07:15 AM   #12
see sig
Old July 15th, 2003, 10:20 AM   #13
alright thanx illusion... will 3 10's fit in the back seat passthru? and does the subs facing the back seats sound better than facing the rear bumper? im looking for a good sounding system that'll still move air... not a competition SPL setup
Old July 15th, 2003, 10:23 AM   #14
2 12" JL AUDIO W6
sealed
eckodlux is offline   Reply With Quote Quick reply to this message
Old July 15th, 2003, 10:26 AM   #15
wolf
you will most def wont to face them to the back. if you want to face them to the front
you will need to seal your trunk. but you will gain about 2-3db
Old July 15th, 2003, 01:05 PM   #16
GreenMachine02's Avatar
Send a message via AIM to GreenMachine02
basslink
GreenMachine02 is offline   Reply With Quote Quick reply to this message
Old July 15th, 2003, 04:42 PM   #17
2 10"mtx 4000 with a 1000 watt Legacy amp
vtridah is offline   Reply With Quote Quick reply to this message
Old July 15th, 2003, 04:56 PM   #18
2 12" 1230 Infinity's in a sealed box
AF_BRYAN is offline   Reply With Quote Quick reply to this message
Old July 15th, 2003, 06:58 PM   #19
1 12" W7 in a sealed box
hotaccord2 is offline   Reply With Quote Quick reply to this message
Old July 15th, 2003, 08:42 PM   #20
bah probably shoulda asked this question in the first place but here goes... could someone write up a quick pros/cons for:
-2 12's
-3 10's
-Facing Back Seats
-Facing Rear Bumper
-Sealed Box
-ported/bandpass box
Old July 16th, 2003, 08:33 AM   #21
My AV6 is all gone...
6spdcoupe's Avatar
Send a message via AIM to 6spdcoupe
2 Diamond Audio TDX 12s/sealed/plexi/etc.. power from Eclipse DA7232.
facing seats..the seats will absorb most of your sound before you can get it.
facing rear..bass will build up using the trunk as another enclosure before releasing it into the car.
Sealed..More accuracy *usually*
Ported/vented/bandpass..more SPL, very tempermental enclosures when building, must be tuned accurately
--Don
6spdcoupe is offline   Reply With Quote Quick reply to this message
Old July 16th, 2003, 08:42 AM   #22
1 12" IDMAX in a 2.0 ft ported box
w3accord is offline   Reply With Quote Quick reply to this message
Old July 16th, 2003, 08:54 AM   #23
chiefy's Avatar
how about some pics
Old July 16th, 2003, 09:08 AM   #24
wow so many sub brands recommended... hmm let's see thus far:
L7, W6, MTX, Infinity, W7, Diamond.
This guy looks bent on either 2 12s or 3 10s... a tastefully built enclosure with 1 high exursion 10.. perhaps the "A" series by eDesigns or a 1 12inch ported IDQ running about 300-400watts clean power will give you excellent *oomph* without sacrificing too much in the SQ department.
Just dont get 3 or 4 subs thinking it's the cool thing to do...
Old July 16th, 2003, 01:15 PM   #25
yea ive gota friend running 2 JL 12W6v2's and wanted something like that... but was just wondering if i could get better sound quality going with 3 10's as opposed to his 2 12's and still get the air moving...
Old July 16th, 2003, 02:30 PM   #26
original member!
Nittanys1's Avatar
id say go with the two 12s the w6 are competition subs and are very nice....2nd to only the W7s JL offers
I have 2 12s Rockford Fosgate XLCs punch
SPONSORS:
Old July 16th, 2003, 02:37 PM   #27
if i were you i would go with 2 12 facing the rear. JL makes good subs. i have had bad experiences with MTX, IDQ, PPI. in other words i blew them all. i have had my twelve's on the same amp and enclosure for almost 4 years now, and no problems. Just My opinion/experience i am not saying others suck
just what i know
Old July 16th, 2003, 03:48 PM   #28
i would do what l_fty suggested..with the money you spent on multiple subs..just get 1 really good one..build the box to recommended specs of the sub..and you should be fine..
sure people can get loud with 2 12s..3 10s..but does it sound good?..thats what it all come down to...sounding good and getting loud..
i wouldnt say the w6 series are competition subs..they are definitely up there though..
Old July 16th, 2003, 04:31 PM   #29
6spdcoupe's Avatar
You mean 2nd to W7 in only the JL line or overall?
'03 6MT Coupe/Navi with Lots of mods...Sold
'05 G35 Premium/Aero/Sport...
Old July 16th, 2003, 04:37 PM   #30
original member!
Nittanys1's Avatar
just JL
