Are CL-S speakers a direct plug-in replacment for 6-gen AV6? - Honda Accord Forum : V6 Performance Accord Forums
Old July 15th, 2003, 05:15 PM   #1
pleae let me know
str8bklam is offline   Reply With Quote Quick reply to this message
Old July 15th, 2003, 09:25 PM   #2
I hope you dont think that the Bose speakers will be able to play using the stock 6gen HU. Size wise they are a direct fit, but impedence-wise they are not. Bose speakers are about 1.57-2ohms per coil in which a special amplifier which is EQ'd to death plays it.
Just pickup some brands that are mentioned countless times here and you'll be set
Old July 15th, 2003, 10:26 PM   #3
I believe i'm getting the stock CL-S amplifier as well. Will that work or would I be better going aftermarket?
Old July 15th, 2003, 10:29 PM   #4
are you getting a CL-S head unit too? if not you're hosed
Old July 16th, 2003, 04:54 AM   #5
nope. I was "thinking" about getting the BOSE speaker and the CL-S amplifier for a good price, but I'll probably reconsider now
illusion: Do you know the specs for the indash OEM Honda 6-disc changer? Does it have a nice internal amplifier? Does it sound clean? i was debaing between it or a Alpine MP3 unit. Any opinions?
Although will a CL-S HU be a direct bolt in? I would possibly pick that up as well
Either way if I don't get the CL-S speakers. I'll get around to installing a set of Infinity CS up front for my highs powered by a small A/B amp and just run the rears off the HU.
Pleaes help me...
Old July 16th, 2003, 07:41 AM   #6
Pleaes help me...
This is the most intelligent thing you said in this entire thread. Go this route. The hassle of custom modifying the CL-S HU into an accord with the attachment of the EQ & Amp...(behind the CL-S HU are two harnesses, one for power/ground/speakers and the other for the EQ torture chamber...) wont be worth it.... you'll get great sound with add on aftermarket speakers, amp
Infinity reference/kappa are a good choice.
Pickup a small amp running around 50-70 watts rms 2 channel and leave your rears powered by the stock HU. JBL, hifonics, visionik, us acoustics, JL "e" series are all good budget-priced amps to look out for
