help with tyc - Honda Accord Forum : V6 Performance Accord Forums
Old April 1st, 2006, 03:14 PM   #1
"Keep It Sleazy"
fluidjay's Avatar
help with tyc
I just searched and couldn't find an answer about a metal brace that comes with your new tyc headlights.The photocopied page(which is so unreadable and can't see any of the diagrams} says that from the factory the headlights in the high or low beam.i can't tell which has a brace that needs to be removed before you can install your headlights.I don't see such a brace myself.So anyone that has done this can yoy tell me where the brace is and how to remove it.
fluidjay is offline   Reply With Quote Quick reply to this message
Old April 1st, 2006, 05:29 PM   #2
Old Member
Du3ce's Avatar
brace?
2007 Accord EX-L V6
Old April 2nd, 2006, 10:53 AM   #3
1lif2liv is offline   Reply With Quote Quick reply to this message
Old April 4th, 2006, 07:48 PM   #4
"Keep It Sleazy"
fluidjay's Avatar
took it to a shop that sells tyc and they said the brace wasn't on this one. anyway it's installed and working fine just have to adjust the daytime running lights they are aimed a little high.
Old April 4th, 2006, 08:06 PM   #5
4 bangin'
Sketch o5's Avatar
where does the brace go? if it goes under the headlights, then its not supossed to come with it, cuz you already have it. head lights and tail lights come ready to be put on.
Old April 4th, 2006, 08:39 PM   #6
I had TYC and I know that Du3ce had TYC also and we dont know that TYC ever came with brace??? Im still confused...
Old April 4th, 2006, 09:11 PM   #7
Suppa Clean 6th Gen
Silver6gen's Avatar
take off your front bumper.... the brace is under the headlight, it will be VERY easy to take out your headlight... you will not beable to take out your headlight unless you take your front bumper off, four bolts two in each wheel well and take all the plastic pops underneath and the two under the hood, do a seach for it and you'll find out how to take it off
btw, nice headlights 1lif2liv : )
Silver6gen is offline   Reply With Quote Quick reply to this message
Old April 4th, 2006, 09:36 PM   #8
First, Thanks for the comment
Second, it wasnt the brace that he said "come with TYC"
The ones you talked about was the stock metal bars that always ON the car and yes, you have to take it of in order to take the headlight off.
Old April 4th, 2006, 11:09 PM   #9
Suppa Clean 6th Gen
Silver6gen's Avatar
my bad i thought thats the thing he was talking about
Old April 5th, 2006, 05:05 PM   #10
wat part do i need to adust to aim my headlites? my passenger side is a bit lower... mite have been altered when i got a fender bender
Old April 5th, 2006, 05:09 PM   #11
^^same question, or what shops will do this kind of service?
maying856 is offline   Reply With Quote Quick reply to this message
Old April 5th, 2006, 09:08 PM   #12
i<3 S.E.S & Eugene Kim
sl33pyriceboi's Avatar
Send a message via AIM to sl33pyriceboi
a fender bender shouldnt have messed up thealightment of ur headlights because the adjusting screws are in the headlight itself....if ur headlight is still on and it looks lie it fits, then its probably not the fenderbender......
y dont you do it urself? take off ur bumper.....do it at night..... use a 10mm wrench n do it...... or you can do wt flux did, and come to my house n ill do it for you.....hahah
or.......GO TO A MEET (like the wed.day ones) and ill aim em for you.......when you giv me my lip
sl33pyriceboi is offline   Reply With Quote Quick reply to this message
Old April 9th, 2006, 09:47 PM   #13
Send a message via AIM to Tuannie
that brace is your bumper support. right under the headlight and it's black
Tuannie is offline   Reply With Quote Quick reply to this message
