Mugen front lip install - Honda Accord Forum : V6 Performance Accord Forums
Old April 18th, 2006, 09:08 PM   #1
i just got the lip in the mail today. after sanding it, priming and painting im almost ready to install but wait! i dont have a freaggggggggggn clue how!
has anyone ever installed a front lip?
Dngrwillrobinson is offline   Reply With Quote Quick reply to this message
Old April 18th, 2006, 09:17 PM   #2
sry.....posted under the wrong topic header
Old April 18th, 2006, 09:48 PM   #3
JB4 e92
clean2draccord's Avatar
You posted in the correct sub-forum.
Your first mistake was painting the lip before test fitting it. Depending on the lip, you can predrill a hole or two in each side and then secure it with some black screws.
Old April 18th, 2006, 09:56 PM   #4
1st of all, thnx for some direction!
when you predrill those holes in the lip itself.........is that going to be more towards the tire wells on the very sides and against the bumber itself?
i only got 2 mounting brackets and no instructions. your helps much appreciated
Old April 18th, 2006, 10:14 PM   #5
JB4 e92
Yes, towards the lip on the bumper near the gravel guard and tire well.
All you'll need to do is mount the lip, and drill directly into the lip and through the bumper. Make sure the hole is positioned so that the head of the screw will be pointing back towards the wheel.
Old April 18th, 2006, 10:16 PM   #6
ej3ffrey's Avatar
Send a message via AIM to ej3ffrey
ya, screw it onto the actual bumper of the car inside the wheel well.
ej3ffrey is offline   Reply With Quote Quick reply to this message
Old April 19th, 2006, 06:31 PM   #7
thanks! im brand new to the site and you guys have helped out a ton already. now, is that the only 2 spots i should be mounting it at?
Old April 19th, 2006, 08:59 PM   #8
JB4 e92
No problem. You'll find that this is a different (in a good way) online community.
You can also mount it from the bottom with the brackets you received. There really isn't a "wrong way" to mount it from below, just as long as the brackets are out of sight.
Old April 19th, 2006, 09:14 PM   #9
ej3ffrey's Avatar
you also might want to put some 3m double sided tape in that middle part that sits on top of the bumper.
Old April 20th, 2006, 07:40 PM   #10
ill get the dbl sided tape that sounds like a good idea.
also wondering if anyone knows where to get more specific and detailed installation instructions. I just dont wanna screw up my car.
before and after pics to come!
Old April 28th, 2006, 08:20 AM   #11
I am the master when it comes to installing mugen lips.....my record so far is 10 min......
maying856 is offline   Reply With Quote Quick reply to this message
Old April 28th, 2006, 12:42 PM   #12
Butta
POLOFOLK's Avatar
Send a message via AIM to POLOFOLK
I have a type r lip painted and ready to go on, but I just have yet to install it.
POLOFOLK is offline   Reply With Quote Quick reply to this message
Old April 28th, 2006, 01:38 PM   #13
ej3ffrey's Avatar
im gonna put my mugen lip on this weekend, ill take pics w/ instructions when i put it on.
Old April 28th, 2006, 06:06 PM   #14
Butta
POLOFOLK's Avatar
After posting in this thread hours ago.... my type r lip is on....
http://www.v6performance.net/forums/...ad.php?t=72508
The thread has pics
