correct bulb - Honda Accord Forum : V6 Performance Accord Forums
Old June 6th, 2006, 10:51 PM   #1
"Keep It Sleazy"
fluidjay's Avatar
correct bulb
I have the second gen of the tyc headlights.the ones where you have to take off the front bumper to install or replace the low beam bulb.However the high beams are easy to access without taking off the bumper, theres just one problem.I purchased some silverstar h1 bulbs to put into my high beams for my daytime running lights.The problem is the bulb is connected in a way i've never seen.The part where you would insert the bulb into the socket is wired from the car to the high beam bulb.the bulb itself has two wires connected to it that run out the rubber bushing and into the plug.I know this probably doesn't make any sense but if someone out there knows how to do this i would appreciate it.
fluidjay is offline   Reply With Quote Quick reply to this message
Old June 7th, 2006, 07:09 PM   #2
"Keep It Sleazy"
fluidjay's Avatar
anyone???????????
Old June 7th, 2006, 07:18 PM   #3
Old Member
Du3ce's Avatar
you need to connect that plug from the tyc into your oem plug.
2007 Accord EX-L V6
Old June 8th, 2006, 09:44 AM   #4
"Keep It Sleazy"
fluidjay's Avatar
But the plug is to the rear of the rubber cover that protects the high beam.If i plug the bulb into there it won't be able to go into the rubber cover because there are wires built into it that go to the bulb that's in there now.i'll take some pics and show you what i mean.
