installing an amp...power stays on even when car is off?? - Honda Accord Forum : V6 Performance Accord Forums
Old July 22nd, 2006, 06:10 PM   #1
got the amp hooked up and it works fine but when i turn the care off the amps power is still on (the light)....why?? even with the remote wire not connected to anything ...I had the remote hooked up to the RADIO fuse but same thing power stays on
what do i need to do? thanks
99accordowner is offline   Reply With Quote Quick reply to this message
Old July 22nd, 2006, 06:22 PM   #2
do you have any additional fuses connected to it? or is it straight connected to the battery?
markus1030 is offline   Reply With Quote Quick reply to this message
Old July 22nd, 2006, 06:28 PM   #3
power wire to the battery red...and then the ground wire to the bolt in the trunk which has other black ground wires going to that bolt...thats it...i dont have the remote hooked up right now...that has to be hooked up? it was but not right now
Old July 22nd, 2006, 06:59 PM   #4
I think the remote has to be hooked up or it stays on.
Old July 23rd, 2006, 03:15 AM   #5
yeh, the remote cable is what switches the amp on and off. needs to be connected to ur headunit
pimpin_turk is offline   Reply With Quote Quick reply to this message
Old July 23rd, 2006, 03:27 AM   #6
... Honda is bliss ...
iLLmAT1k's Avatar
Send a message via AIM to iLLmAT1k
That is right. Make sure you also have a circuit breaker if you're running high wattage so you wont keep blowing fuses. And also have an inline fuse approx. 16" from the battery. Remote wire is like a power switch for the amplifier(its mandatory). If the headunit is off, the amps should be off. Gluck.
iLLmAT1k is offline   Reply With Quote Quick reply to this message
Old July 23rd, 2006, 08:56 AM   #7
LaLaLaLa
stupidaznmunkey's Avatar
yeah the amp will stay on unless the remote is hooked onto the HU
Old July 23rd, 2006, 12:30 PM   #8
jdm_dynasty's Avatar
wire the remote to the blue wire on the headunit. that's for an aftermarket headunit. not sure about OEM.
jdm_dynasty is offline   Reply With Quote Quick reply to this message
