tl-s seats into an accord? - Honda Accord Forum : V6 Performance Accord Forums
Old August 1st, 2006, 08:14 PM   #1
has anyone done this? i have the seats at the shop and we are going to put them in tmrw but i was wondering if we are going to run into problems fitting in the rear seats? not sure if they are a direct fit.
mrtien is offline   Reply With Quote Quick reply to this message
Old August 1st, 2006, 08:20 PM   #2
4.0L
VietNinjaJ30A1's Avatar
don't think the rear seats are a direct fit. the front ones should be. let me know how those work out...i want the CLS seats. are the TLS buckets?
VietNinjaJ30A1
2000 Honda Accord V6 Supercharged
Official Slammed Club Member #36 (Stage 1)
Old August 1st, 2006, 08:24 PM   #3
pretty sure tl-s and cl-s are identical for the most part, only tl-p are different
i am hoping they will fit...somehow or another
Old August 1st, 2006, 09:28 PM   #4
4 bangin'
Sketch o5's Avatar
thatd be sweet if the front ones fit. too bad they dont make em in tan cloth, haha.
Old August 2nd, 2006, 01:30 AM   #5
Above 85
CL-S and TL-S seats are heated, why install something that you can't use, unless you plan on wiring it and that's going to be a pain
MichaelQ is offline   Reply With Quote Quick reply to this message
Old August 2nd, 2006, 03:44 PM   #6
Texas Made to the Fullest
Tx_Accord98's Avatar
Send a message via AIM to Tx_Accord98 Send a message via Yahoo to Tx_Accord98
people do mods like this for the same reason some of us have a tls steering wheel. it just looks better.
Tx_Accord98 is offline   Reply With Quote Quick reply to this message
Old August 2nd, 2006, 03:57 PM   #7
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
do the cl rear seats fit in the accord coupes?
Old August 2nd, 2006, 06:57 PM   #8
how can you not use it? wiring is simple as hell you just wire power/ground with the switch (which i already have) the heater assembly is built into the seat
and i can sit on it? and they look better?
Old August 2nd, 2006, 11:32 PM   #9
4 bangin'
Sketch o5's Avatar
it wouldnt be a pain to wire up heated seats. prolly pretty easy actually.
Old August 4th, 2006, 10:55 AM   #10
Work hard...play harder!
OCdjg's Avatar
Send a message via AIM to OCdjg
anyone have pics of the seats?
OCdjg is offline   Reply With Quote Quick reply to this message
Old August 4th, 2006, 11:14 PM   #11
Senior Member
Jaegray09's Avatar
TL Seats = http://media.mainstreetcommerce.com/...4-1696fed5ca80
mrtien... did they fit?
Jaegray09 is offline   Reply With Quote Quick reply to this message
Old August 5th, 2006, 03:27 PM   #12
they go in tuesday ill let yall know
front is gonna fit we already checked the rail pattern from the TL vs. accord
rear..may have to make some custom brackets
Old August 5th, 2006, 07:31 PM   #13
how are you planning on changing the rear deck where the speakers are. i'm curious for a later project.
Old August 5th, 2006, 08:16 PM   #14
Senior Member
Jaegray09's Avatar
What about the electronics for the front seats?
Old August 7th, 2006, 12:32 AM   #15
rear deck is untouched, seats are just the seats alone..
and the electronics, we are wiring the passenger power motor into the driver side power harness
Old August 7th, 2006, 08:46 AM   #16
Senior Member
Jaegray09's Avatar
Driver's side is plug and play?
Old August 7th, 2006, 10:52 AM   #17
yea its the same motor from the accord, well at least if you have an EX model
Old August 7th, 2006, 03:17 PM   #18
Senior Member
Jaegray09's Avatar
Oh ok, having a 1998 I was wondering if maybe the TL had a side airbag, but I guess that would be on its own harness. I need a new seat, mine is broken.
Old August 7th, 2006, 07:16 PM   #19
it does have side airbag but thats a different story
