The Definitive Guide to 6th Gen Steering Wheel Swaps - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
Old May 6th, 2007, 07:24 PM   #1
Fast at Last!... kind of.
Steverino's Avatar
First things first, check if your Accord is a single or dual-stage airbag. I've only ever encountered ONE 6th gen that was dual-stage (but that was probably nobody checked around for me....) anyway. CHECK FIRST BEFORE BUYING ANYTHING!
How do you check?
If you open the cover located at the bottom of your steering wheel and discover a plug that has 2 wires, then you are single-stage airbag. If you have 4 wires, then you're dual-stage.
Steering wheels with single-stage airbags
JDM Integra Type-R (DC2)
2000-2003 S2000
2002+ JDM Integra Type-R (DC5)
2002-2004 Civic TypeR (JDM)
Same as JDM ITR
Steering wheels with Dual-stage airbags
2004+ S2000
(note the different emblem than the pre-2004 S2000)
2002+ Acura RSX
2002-2004 Civic SiR (USDM)
Looks the same as JDM Civic Type-R wheel
These installation instructions are very easy to follow:
http://www.handa-accessories.com/accord/accwoodwhl.pdf
Some Notes:
* JDM wheels don't come with cruise controls, at least, I've never seen any. What you can do is get a wheel that does come with the cruise control and swap them. I personally took the cruise control buttons from the S2000 wheel and installed it into my DC5 steering wheel). Probably not the cheapest mod to do, but sometimes you have to spend some extra $ to stay unique.
* The RSX, Civic Type-R, Integra Type-R (DC5, not DC2), and EP3 wheels are all anatomically the same.
* S2000 wheels are the only wheels that have perforated leather.
* JDM wheels come with Momo embossing on the wheel (DC5 and DC2)
* If you are only swapping the steering wheel (ie: Accord -> TL Type-S wheel, airbag and cruise control remain un-touched)
Cruise Control Swap
If you're swapping cruise controls:
Follow these instructions only if you're swapping into a new cruise control unit. If you're doing an Accord -> TL swap, you can re-use the cruise.
1) Take a look at the green cruise control plug of the Accord, it should have 4 pins:
Plug on the Accord cruise control with the unit facing normal so you can read it:
GROUND
RESUME
SET
BLANK
You may want to label these wires as you are removing them, so you don't get them mixed up. DO NOT mix them up, or your cruise will not work.
You'll need to remove the wires from the Accord cruise control and place it into the S2K green holder. If you look at the plug, you should be able to flip up a latch that hold the wires down. Using a thumbtack, push the wires out from the front.
Re-insert the wires into the S2K cruise holder in the following order:
Plug on S2K cruise control unit facing the same way as the Accord one
RESUME
BLANK
GROUND
BLANK
SET
Should look like this when you're done:
Hopes for a sticky...
Steverino is offline   Reply With Quote Quick reply to this message
Old May 6th, 2007, 07:44 PM   #2
Formerly VTEC-v6!
N54TT's Avatar
Sticky granted
Garage:
  • 2017 Chevy Tahoe LT
  • 2016 BMW 535i M-Sport
Gone but not forgotten:
  • 2010 BMW 135i (500hp, JB4 w/ E85)
  • 2013 Honda Accord 4dr EX-L
  • 2002 Honda Accord 4dr EX-V6
  • 1999 Honda Accord 4dr LX
Old May 7th, 2007, 10:47 AM   #3
Boosted!
ComptechV6's Avatar
very helpful.
Old May 20th, 2007, 11:25 PM   #4
Send a message via AIM to five0netvv0
very nice....can we add the tl-s perforated steering wheels too?
five0netvv0 is offline   Reply With Quote Quick reply to this message
Old May 21st, 2007, 08:25 AM   #5
Boosted!
ComptechV6's Avatar
Yes it has been done countless times
Old May 21st, 2007, 08:43 AM   #6
so which 6th gen cars have the dual stage???? im curious cuz i rmember my yellow connectors weren't connected and that mite b the reason my SRS lite is on!!!
Old May 29th, 2007, 12:31 AM   #7
Steverino's Avatar
Why are you so curious as to what other people's cars have? Who cares? Worry about your own damn car first.
Read the first paragraph. Thanks.
Old August 21st, 2007, 06:33 AM   #8
great help thanks,our uk accord is single stage airbag, does that mean any honda single stage airbag will fit??, dc2,dc5 ,early s2k,ep3, are the boss bolts universal
v6 type s is offline   Reply With Quote Quick reply to this message
Old August 28th, 2007, 01:22 AM   #9
Supernova m33
ngc604's Avatar
Send a message via AIM to ngc604
i know we can use the 6th gen airbag on the 01-03 tl/cl swap. but can we use our airbag on the 7th gen wheel?
http://cgi.ebay.com/ebaymotors/NEW-O...spagenameZWDVW
wheel part looks similar to the tl/cl ones i have seen. any ideas?
ngc604 is offline   Reply With Quote Quick reply to this message
Old September 19th, 2007, 10:41 PM   #10
Steverino's Avatar
Err... I don't think so. I think dimensionally they are different.
Old November 11th, 2007, 05:34 PM   #11
CyN13's Avatar
2002 v6 accords are dual stage.
CyN13 is offline   Reply With Quote Quick reply to this message
Old December 1st, 2007, 01:38 AM   #12
hmm... I need to look into mine. I have an 02 coupe i4 and I kinda want to get this wheel and sell my TL-S
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29
LyttleViet is offline   Reply With Quote Quick reply to this message
Old December 1st, 2007, 03:10 AM   #13
CyN13's Avatar
thats a nice steering wheel, i found one after i bought the DC5 one. I like that one alot
Old December 1st, 2007, 03:22 AM   #14
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
Cool thread...Cant believe I havent seen this before.
Steverino - Do you have pics of your Cruise control switch from the ap1 installed? I have a Euro-R wheel, which is basically the DC2 wheel, and im dieing without Cruise on the freeways...
Old December 1st, 2007, 03:42 AM   #15
ok, I looked at the yellow harness which seems to be the one pictured as AIRBAG harness above and it has 4 wires so there goes my dream =(.
Old December 1st, 2007, 03:47 AM   #16
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
im 100% sure that the yellow is SRS..
Old December 1st, 2007, 03:59 AM   #17
grey next to it is 4 wires too =(
Old December 1st, 2007, 11:09 AM   #18
CyN13's Avatar
no your dreams arent gone yet. you can switch from stage one to stage 2.
Old April 9th, 2008, 11:22 AM   #19
thanks helpped alot!
accordsoul is offline   Reply With Quote Quick reply to this message
Old June 29th, 2008, 11:30 AM   #20
Very helpful. Will come useful next week. =)
Hondastylez is offline   Reply With Quote Quick reply to this message
Old July 1st, 2008, 11:25 AM   #21
Does anyone have the Acura part number for the tl-s or mdx steering wheel, all black w/ perforated leather?
bmulder is offline   Reply With Quote Quick reply to this message
Old August 23rd, 2008, 03:46 PM   #22
Some of the other Honda wheels you showed on here are pretty clean looking inside.
skolldogg is offline   Reply With Quote Quick reply to this message
Old September 6th, 2008, 02:05 AM   #23
v not some model, my girl
99v6sedan's Avatar
ok so does anyone know why the factory wood grain steering wheel says it will ONLY fit the 01-02 models? ive heard that there is a difference in airbags. i would just like to know if anyone knows for sure whether or not i could make it work.......
http://cgi.ebay.com/ebaymotors/Genui...spagenameZWD1V
Old September 6th, 2008, 10:17 AM   #24
99v6sedan's Avatar
anyone?
Old September 6th, 2008, 12:13 PM   #25
Steverino's Avatar
The 01-02's had dual-stage airbags, I honestly don't see why it wouldn't work in terms of hub-fitment, why? You want to put a woodgrain steering wheel on? :O
Old September 6th, 2008, 02:03 PM   #26
99v6sedan's Avatar
^yea i want it. ive wanted it since i bought the car ive just never really looked into it. then i decided to ditch the wood inside and got all my wood overlaid in CF. after putting my air ride on i decided to go towards VIP so i put all the "wood" back in and wanted to get the wood steering wheel too.
Old September 19th, 2008, 04:54 PM   #27
Jake05's Avatar
This is very helpful, great job
Jake05 is offline   Reply With Quote Quick reply to this message
Old November 3rd, 2008, 12:57 AM   #28
RJV3's Avatar
Soooooooooo
Does the wood grain 01-02 steering wheel fit the 00 coupes?
RJV3 is offline   Reply With Quote Quick reply to this message
Old November 3rd, 2008, 10:24 AM   #29
*VIP ACCORD*
BlackDeathV6BG's Avatar
Send a message via AIM to BlackDeathV6BG
Doess anybody know what the JDM CL7 steering wheel is? Single or Dual?
CANIBEAT
SpoonCertified #00720
Flickr&mpt=[CACHEBUSTER]">
BlackDeathV6BG is offline   Reply With Quote Quick reply to this message
Old November 3rd, 2008, 11:00 AM   #30
4.0L
VietNinjaJ30A1's Avatar
^^ is the JDM CL7 wheel different from the TSX wheel other than having an H rather than an A?
