Has anyone put Ultra Bulbs on aftermarket headlights? - Honda Accord Forum : V6 Performance Accord Forums
Old May 29th, 2007, 11:05 PM   #1
I has aftermarket black housed headlights and I i bought the 9005 and 9006 sylvania ultra's and have know idea how to install them.. The bulbs doesn't simply come out.. it has screws and what not... yes i am knew to the entire experience but i appreciate the help.. thanks
b2theran1 is offline   Reply With Quote Quick reply to this message
Old May 29th, 2007, 11:27 PM   #2
ExSlammed Club Member #52
a99blackaccord's Avatar
Send a message via AIM to a99blackaccord Send a message via Yahoo to a99blackaccord
The bulbs should just turn and come out of he headlights. I used to release the socket from the bulb first, then turn and pull the bulb out of the headlight. I dont know why the bulbs would not just come out?
a99blackaccord is offline   Reply With Quote Quick reply to this message
Old May 29th, 2007, 11:31 PM   #3
jdm_dynasty's Avatar
it should twist counter clockwise, if i remember correctly. first, unplug the socket, this might take awhile. after that, twist it as hard as you can and it should come out.
jdm_dynasty is offline   Reply With Quote Quick reply to this message
Old May 30th, 2007, 12:21 AM   #4
Champaned_out's Avatar
ive heard alot of people wasting money on sylvania bulbs... people complained the bulbs blew out anywhere from 1 to 6 or 7 months after installing them
Old May 30th, 2007, 08:58 AM   #5
Senior Member
Jaegray09's Avatar
I've heard this, too. But, I decided to buy a pair of Silver Star Ultras anyway. They are said to last 30% longer than the previous model, so I thought it was worth a try. I have had them for about 9 months now and haven't had a problem.
I should also mention that they really do light the road much better than the OEM bulbs I had (certainly no retro, though). I live in a suburban area with dark streets and a lot of deer, so the light really helps. Eventually I would like to go retro, but I cannot afford the time or money right now.
Jaegray09 is offline   Reply With Quote Quick reply to this message
Old May 30th, 2007, 10:39 AM   #6
can't rmember the last time i had OEM bulbs...but comparing oem stanley 9006 bulbs to the ricer bulbs... they r WAY larger and thicker glass bulb! im not even sure if my 8000k hids have more lite or less lite output then stock oem bulbs?
Old May 30th, 2007, 10:39 AM   #7
have you tried the 9005 to 9006 conversion yet? meaning, having a high beam bulb inside the low beam housing? that's what i'm using right now and it helps probably about 20%-30% better than low beam. it's not hard at all. all you need to do is dremel the center piece of your socket and that's it. the fitment is perfect.
Old May 30th, 2007, 12:37 PM   #8
whats is my best bet on hooking up these cheap fog lights i bought at my local car store... they are listed as blazer's hid style... i really dont know where to run the wires.
Old May 30th, 2007, 04:26 PM   #9
MASTER OF MAYHEM
Joepro's Avatar
Send a message via AIM to Joepro
Ya, do this its worth it, cheap lighting upgrade.....it works great, there is a positive difference in the lighting output.
Joepro is offline   Reply With Quote Quick reply to this message
Old May 31st, 2007, 10:14 AM   #10
so 9005 bulbs r just briter lite output then 9006s?
Old May 31st, 2007, 05:19 PM   #11
MASTER OF MAYHEM
Joepro's Avatar
there 65w vs 55w, so therefore they are brighter.
