Need help with DIY mod of Mugen front lip onto 01-02 coupe bumper - Honda Accord Forum : V6 Performance Accord Forums
Old August 21st, 2007, 02:19 PM   #1
ong-boi's Avatar
Send a message via MSN to ong-boi
i hope i've posted in the correct place, wasn't a DIY section...or i'm just blind lol
So i've searched up a few forums (6thgenaccord and torontoaccords) including this forum, and I have yet to find much info pertaining to my topic.
Just want to know what was needed/done to make a Mugen front lip fit on to an 01-02 coupe bumper.
I know it's possible to find the 01-02 lip out there, but i can probably pick up the 98-00 coupe mugen lip for cheap so just wanted to see what the process involved in making it fit on the 01-02 coupe bumper
any help is appreciated!!
ong-boi is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2007, 11:31 AM   #2
POS driver
98CG__sHow's Avatar
Send a message via AIM to 98CG__sHow
all you do is cut the inner tabs to make it fit..
heres a short tutorial
NOTE: the pic is a pic of a civic mugen lip..but i just used it to show you with the red circle where you are suppose to cut...cut a little bit at a time so that you could fit it in...or else youll have some sick gaps..
98CG__sHow is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2007, 11:33 AM   #3
Derek
damage2000's Avatar
Nice upgrade, I'm sure you're going to keep this secret on TAC, hope it works out well, would like to see the final product once your done.
damage2000 is offline   Reply With Quote Quick reply to this message
Old August 22nd, 2007, 11:08 PM   #4
ong-boi's Avatar
Awesome!! thanks 98CG__sHow, that's all i wanted to confirm!
Derek, well some of the guys know already.. but it'll be different as i have yet to see any other accords in Toronto with this set-up! but once i pick up the lip and fix up the bumper+paint, hopefully i can make it out before the seasons over!
Old August 23rd, 2007, 12:04 AM   #5
not sure about coupe, but on the sedan, I had to completely remould the shape of the lip.
Not only did I have to cut the tabs, I had to change teh curves of the lip by using a heat gun, softening the plastic and then pressing onto the bumper to obatin the desired shape. takes a bit of work but well worth it once complete.
SiReal is offline   Reply With Quote Quick reply to this message
