How to Bleed your own brakes with a SPEED BLEEDER - Honda Accord Forum : V6 Performance Accord Forums
Old September 3rd, 2003, 12:34 PM   #1
QuizWORX's Avatar
Speed Bleeder® is the patented bleed screw (nipple) with the built-in check valve, it is truly a one-person bleeder screw. Once installed, it becomes a permanent part of the brake system. We have been selling them for several years and have received many positive comments.
To bleed your brakes, loosen the Speed Bleeder® ¼ - ½ turn and pump the brake pedal. When the pedal is depressed the pressure generated opens the check valve, letting air and brake fluid out of the end of the Speed Bleeder®. When you release the pedal and it returns to the up position, the check valve closes and prevents any air from re-entering the system through the Speed Bleeder®. When bubble-free fluid is evident you close the Speed Bleeder®.
In the closed position it works just like a standard bleed screw and prevents any brake fluid from leaking out. It generally takes about 5 pumps to purge each caliper or wheel cylinder. That is all there is to bleeding your brakes.
Injen Intake, Injen Heat Shield, Hayden Transmission Oil Cooler, Denso Iridium Sparkplugs, APEXi WS Cat-back exhaust (single), SPE Helix Throttle Body Spacer, Hyper Ground System, Hyper Voltage System.
Cross-drilled, Eibach Pro-kit Springs, 5Zigen 5ZR 225/40 R18 2pc, Pirelli P-Zero Nero 225/40 R18
Levoc pedal, Razo shift knob, 2002 Accord Head Rest, H.I.D. 10k Headlight, Rosen R6500 Double-DIN DVD/CD/MP3/TV/AM-FM Stereo, NAV Ready
Honda OEM Body kit, Honda OEM Spoiler
QuizWORX is offline   Reply With Quote Quick reply to this message
Old September 3rd, 2003, 01:56 PM   #2
Senior Moderhater
abram2001's Avatar
sounds real easy, this might be easy to do on a more frequent basis.
Old September 3rd, 2003, 03:33 PM   #3
Thanks for the sticky.
AjIsDope is offline   Reply With Quote Quick reply to this message
Old September 3rd, 2003, 03:52 PM   #4
QuizWORX's Avatar
i think this thing is available at PEPBOYS.
Old September 3rd, 2003, 04:03 PM   #5
It sure is!
Old September 9th, 2003, 09:58 PM   #6
great.. they didn't have accord application 2 years ago.. now they do.. too bad I already bought new honda screws
ForceSHO is offline   Reply With Quote Quick reply to this message
Old September 14th, 2003, 01:26 AM   #7
J32A2 + SC + Meth AV6
BlackV62K2's Avatar
Sorry for the dumb question, but what do you benefit by doing this?
Old September 14th, 2003, 01:28 AM   #8
Senior Moderhater
abram2001's Avatar
more time to spend with the ladies
Old October 29th, 2003, 10:30 AM   #9
The Old Man
Send a message via AIM to trafficjam
Wouldn't the fluid level get low after pumping it a few times?
How much are these things? Why not use a Motive bleeder?
trafficjam is offline   Reply With Quote Quick reply to this message
Old December 22nd, 2003, 12:49 AM   #10
what does bleeding the brakes actually do? Have no clue here and neither does another....
NocturnalCoupe is offline   Reply With Quote Quick reply to this message
Old December 22nd, 2003, 05:54 PM   #11
TQ challenged
ironmonkey's Avatar
Brakes are critical. Have a trained mechanic do all brake work if your not sure.!
Bleed , to open a small bleeder valve located on each brake caliper to remove trapped air in the brake system. Air will cause poor brake feel and spongy brakes ,because air is compressible.
Its usually done after replacing hoses or calipers.
I have also used the bleeders to flush the brake system.
Flushing every 2 years clears out all the old fluid contaminated with rust and water. Rust will kill your ABS motor and other expensive brake parts. Water will turn to steam under hard braking .
ironmonkey is offline   Reply With Quote Quick reply to this message
Old December 22nd, 2003, 06:07 PM   #12
V Go SoCal Drivers V
bustedryde's Avatar
Yeah, if nothing else, just change every 3 years.
