DIY Motor mount Insert - Honda Accord Forum : V6 Performance Accord Forums
Old December 5th, 2003, 08:12 PM   #1
FREUNDE MIT DEM TEUFEL
jimmyrecluse's Avatar
Hello,
I kept breaking the top motor near the power steering pump on my 6th gen V6 accord.
This only happend after I installed my 6spd trans, however, I have heard of guys with just the SC break them too.
Since I couldn't find mount inserts I made my own!
1. Buy the new mount or completely remove your unbroken old one.
2. Go to your local plastics store and buy the hardest polyurethane you can. It will have the poly and the hardener and shouldnt cost you more than 20.00 so dont buy too much.
3. Use a condom or plastic wrap seal one end of the mount. The mount is circular. Lay it on it's side and cover the side that is facing up at you.
4. Mix 1/4 of your hardener and poly according the the instructions. You might need a small balance scale.
5. Turn the mount over so the sealed side is on the table and the open side facing you.
6. Pour a small amount of the mixed poly into the mount. Just enough to fill up about 1 inch of the mount. Let it dry.
7. After the bottom dries mix the rest of your hardener and poly and fill the mount up.
8. Let it dry and then good luck removing the plastic or condom form the mount. If you use a condom tie up the end so the poly doesnt run out into it. Plastic works better if you got it.
I'll post pics later of the finished mount installed already sorry.
jimmyrecluse is offline   Reply With Quote Quick reply to this message
Old December 6th, 2003, 12:13 PM   #2
energy suspension dosent make a set for this car?
Old December 7th, 2003, 06:21 PM   #3
Couldnt find any.
Old December 15th, 2003, 01:50 PM   #4
Your V12, My V-twin.
JonHsiung's Avatar
Which condoms work best? j/k.
Good writeup - too bad for me i already broke two engine mounts (crazy driving) and replaced them both with OEM .
2000 AV6 Coupe
- J O N -
Old February 25th, 2004, 05:14 PM   #5
wicked euros's Avatar
Send a message via AIM to wicked euros Send a message via Yahoo to wicked euros
Can you post up pix? Also where can I find a place in my area to buy polyurathane?
R I P
'01 V6 Accord sedan
14.80 @ 95.2 mph
'02 Odyssey
wicked euros is offline   Reply With Quote Quick reply to this message
Old February 25th, 2004, 05:34 PM   #6
Look for a plastics store in your area or try a hobbie shop. I dont have any pics cos my DC broke. But it is simple. You know what mount I am talking about right? just seal off one side of it and dump your urethane inside 1/4 ways when it starts to dry pur in the rest filling it up.
Old February 25th, 2004, 06:25 PM   #7
I know what mount you are talking about. Ill have to look around at the hobby shops to see if i can find some.
Old February 25th, 2004, 06:37 PM   #8
just do a yahoo searh in yellow pages for plastics.
Old October 9th, 2004, 02:23 AM   #9
V6P Lover
v62kaccord's Avatar
Send a message via AIM to v62kaccord
hey how do you check if the motor mount is broken...
v62kaccord is offline   Reply With Quote Quick reply to this message
Old October 11th, 2004, 09:25 AM   #10
Just look at it. If the rubber is separated and torn then its bad. You will also hear and feel the motor banging around.
Old October 11th, 2004, 10:00 PM   #11
V6P Lover
v62kaccord's Avatar
^ kool thanx
