Need Help with Removal Of Backseat and Door Panel - Honda Accord Forum : V6 Performance Accord Forums
Old January 5th, 2009, 12:14 PM   #1
Hippie
Accord2000's Avatar
Send a message via AIM to Accord2000
Can anyone help me out with instructions on how to remove the backseat of my 6th Gen 2DR and also the door panel? Any input would be awesome I have some small maintenance that needs to be done that I know I D.I.Y. but would like not to mess up any door clips or whatnot in the process.
Accord2000 is offline   Reply With Quote Quick reply to this message
Old January 5th, 2009, 03:10 PM   #2
do you want to remove just the bottom of the seat or the seat back too?
I'm pretty sure to remove the bottom you just pull up on the front of it.
to remove the door panel you have to unscrew a screw in the bottom of part of the door you pull to close it, and then remove the one behind the door handle.
take the little triangular piece off that is on the inside of the rearview mirrors, then remove the little plastic pin that is below the triangular piece with a screwdriver. Then remove the entire door handle assembly by pulling it back and then forward and pull out at the same time. once that is off, remove the little clip on the metal rod that is connected to the door handle. once that is off, just give the entire door panel a good yank and then pull up to release all the clips. then unclip the wire harnesses from all of the controls. don;t worry about bending the clips too much, since they're pretty hard to bend
3macsandapc is offline   Reply With Quote Quick reply to this message
Old January 6th, 2009, 04:16 PM   #3
Hippie
Accord2000's Avatar
yeah the backseat was easy just push foward and lift and the door panel I just took my time with it slowly and finally got it off and back on with no problem thanks for the feedback
Old January 8th, 2009, 06:49 PM   #4
┌∩┐(◣_◢)┌∩┐
skatingclaybird's Avatar
hey my back seats are bolted down though by a ten mm nut
Old January 9th, 2009, 04:02 PM   #5
Hippie
Accord2000's Avatar
the bottom of the seat or the seat backs themselves?
Old January 9th, 2009, 11:42 PM   #6
┌∩┐(◣_◢)┌∩┐
the bottom cushion you sit on....the bolt is attached to a piece of metal that is connected to the back of the cushion
Old January 10th, 2009, 12:02 AM   #7
thread killer
hmm...i used to always take the back seats apart and don't remember any bolts on the bottom cushion...only bolts are on the latch for the back piece
eh either way everyone knows how to do it now
